Question about Haier 42EP24S 42 in. EDTV-Ready Plasma Television
Haier HL26R-B LCD-TV no power up
I just opened the back of the LCDTV thinking that the fuese was bad, to my surprise this set doesn't have a fuse, it does have a TVR 1645.
any ideas/suggestions concerning my probem would be greatly appreciated
  • 585 Answers
There is a repair kit for these haier sets part# TV-3910-01
you can try encompassparts.com and make sure this kit fits your model. The kit includes a few boards that need to be installed together.
Thks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Jul 14, 2010
Haier TV buttons usually don't work
does it connect to the internet? most new tv's now connect to the internet. through doing this it should do an update and possibly fix any issues you may have.
hope this helps
Jun 17, 2013 | Haier HL26R 26 in. LCD TV
Haier lcd deaD
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
I hope this solution will be helpful...
Thanks for using fixya...
Nov 07, 2011 | Haier HL42XD1 42 in LCD TV
My haier 42 inch tv is stuck on the white multimedia player screen and wont respond to anything
Hi check the power supply some of the capacitors sometimes go bad. They are easy to see because they will bulg on top. Be carefull opening up the TV it had high voltage you might want to leave it unplug for a couple of hurs before opening it up.
Jun 02, 2011 | Haier HL42XD2 42 in LCD TV
Hi I have a ViewSonic monitor and when you start it, it comes on but it goes black. You can see that the image is in , it starts blinking ,but you can see that the image is there. I changed the cable...
It may have bad caps, transistors in the power supply/inverter circuits as you can see here:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX715/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 30, 2011 | ViewSonic VX715 17" LCD Monitor
Monitor will not turn on checked on connections. Only two years old
Two yeras old is about right, I am not surprised, just fixed two years old SAMSUNG 32" TV due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 27, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Haier HL26R COMCAST REMOTE CODE
what kind of comcast remote do you have please describe, black and silver, dta, and especially important what color is the OK/select button grey or red. If the Ok/select button is red the codes are 11034, 10768, if the ok select button is grey there are no codes, however you can use the search option listed below
step 1 press the tv button located at the top of the remote
step 2 press and hold the setup button located on the upper right of the remote until the tv button blinks red 2 times.
step 3 enter code 991 the tv button will blink 2 times again
step 4 alternate pressing the grey Power button then the tv button located at the top of the remote ( the tv will turn off when it finds the correct code)
step 5 press the Setup button when the tv turns off and the tv button will blink 2 times confirming the code is locked in
FYI this process can take quite some time but there is no direct code listing for the non dvr remotes.
Good Luck
Jun 20, 2009 | Haier HTF20R21 20" TV
Viewsonic N3251w 32inch LCDTV that does not have
It's most likely a capacitor. Open up your television, and look at your power circuit board. Look to see if any of the capacitors are blown.(the will be bulging look up an image of a blown capacitor to get a better image if not known already. Mine was (CS19, CS21, CS22, CS23) Also on (C672) from the Circuit Board.Can you look at the voltages of these for me? I'm missing the capacitors.
May 04, 2009 | ViewSonic N3735W 37 in. LCD TV
Remote codes for Haier tv sets
I saw the post above about an association with Hitachi and it worked for me. I have Haier model HL40XP1 and used the Hitachi code 10056.
Jul 15, 2008 | Televison & Video
Fuse Blowing
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Jun 02, 2007 | Sylvania 6626LCT 26 in. LCD Television
Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
340 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
