Question about GE JKP45 Electric Double Oven
Locked after self clean cycle
I have a GE double oven model JKP54GOP and after running the self clean cycle, the top oven has remained locked 24 hours later. I turned off the circuit breaker but the door remained locked. The "locked" indicator also doesn't go away. I can remove the door by lifting it out. I tried to move the lock arm but is it firmly stuck. Is there a way to release it? Is the problem electrical or mechanical?
Thanks for your help,
Steve
    President:
  • 1,891 Answers
You may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Posted on Jul 15, 2010
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
I need to clean my double ovens, but do not have the owner's manual. I know that I simple press the Clean button, but how long do I set the timer for?
You only need to reset the time if you want a cleaning cycle other than 4 hours. The default start is press Self-Clean then Start. Otherwise, press Start, type in a time between 3 and 5 hours (Min/Max cycle length) and then press Start. Do this with the number pad, do not press the Timer button. If you wish to clean both ovens, the second one will start when the first one finishes.
The Locked door light will go off when the oven has cooled below the Lock temperature. If you interupt the cleaning cycle by pressing Clear/Off, the door will remain locked until the oven cools.
I hope this helps.
Sep 25, 2010 | GE Profile JTP56 Electric Double Oven
Fan stuck on, door locked
Hello,"If actual over temperature condition occurred"
Look for welded relay contacts. If this happens,replace oven control (also called clock or ERC).
IF NO OVER TEMPERATURE condition occurred: Look for high resistance connection or any other cause of high resistance in the oven temperature sensor circuit.Check sensor, sensor harness and sensor harness connection at sensor and oven control .Replace sensor if found defective.Check door lock switches.
REMEMBER: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Thanks
Jun 01, 2010 | GE Profile JTP95 Electric Single Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Jan 02, 2009 | GE Profile JT952 Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Oven remains locked after self cleaning
I ended up paying an independent appliance repair man $149.00 to fix my problem. However the "fix" also includes the fact that I can never lock the oven again.
Nov 22, 2007 | Viking 27" Professional Select Built-in...
GE JKP45 Electric Double Oven Logo
373 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
