Question about Whirlpool LGB6300 Gas Dryer
It's completely dead. won't turn on when push button. dial works fine. is it a blown fuse?
  • 5,911 Answers
If the model number you listed this question under is correct, there is a Thermal Fuse in the back of the dryer that, if blown, will prevent the dryer from running. To access, follow these steps:
1. UNPLUG dryer and SHUT OFF gas supply.
2. Locate and remove the rear panel screws on the back of the dryer.
3. With the rear panel removed, the Thermal fuse will be located on the blower fan housing on the left-hand side of the dryer (as viewed from the rear). It is a small plastic looking component with two wires attached.
4. Disconnect the wires to iosolate the fuse and measure across the leads with a multi-meter. The fuse should read a short (0 ohms) if good. If it reads an open (infinite), the fuse is bad.
NOTE: If you do not have a multi-meter another simple way to prove the fuse bad is to make sure the dryer is UNPLUGGED and disconnect the two wires from the fuse and jumper them together. Plug the dryer back in and, if it runs normally with the fuse by-passed, the fuse is bad. CAUTION: DO NOT leave the dryer by-passed in this manner, Use only as a TEMPORARY means to troubleshoot your problem.
If the thermal fuse is blown, it generally blows for a reason. Most commonly, this is caused by a dryer that is overheating. I would recommend that you fully inspect your dryer ventilation ducting inside the cabinet and from the point where it leaves your dryer to where it exits you home. Make sure there are no kinks, clogs or choke points that will keep the dryer from ventilating correctly. A dryer in a clogged state will not heat efficiently and will eventually overheat to the point of failure. This will result in repeated failures of any components you may replace.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list have helpful exploded view diagrams to assist you with locating and properly identifing any parts you may need. The Thermal Fuse part number is 3392519 and is listed as item 7 under the "Bulkhead" parts listing.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Jul 14, 2010
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
What are the possible reasons my 97 geo metro won't turn over after running the battery dead, then replacing it with a brand new battery ?
blown fuse.
bad wiring
forgot to charge new battery up to 12.6vdc reseted.
the head lamps work , keys in pocket (by law) and
are #1 first thing to trouble shoot when dead (easiest)
so, got 12v at all under hood fuses? ????????
id bet not. and any $10 voltmeter can find this easy.
buy one. use it. and save a bundle....
Aug 24, 2014 | 1997 Geo Metro
Goldwing won t start
Check for any blown fuses or relays, check the starter switch to make sure power is going into the switch and out to the starter solenoid, if there is power coming from the switch to the solenoid but the starter wont turn you will have to have the starter checked or replaced.
Jul 16, 2014 | 1999 Honda GL 1500 SE Gold Wing
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Re: mcm111ow, it was working fine, now no signs of life, no lit dial.
Check main fuse if completely dead. Replacements available below if blown:
http://www.electronix.com/microwave-repair-c-557.html
Mar 30, 2011 | Magic Chef MCD1311ST Microwave Oven
Dead, replaced battery and still dead
your fuse is blown near the battery is a fuse check if it is blown
Jul 24, 2009 | 1995 Suzuki VS 800 Intruder
No power
there are six screws in the base and two in the back of the unit. After taking off the top I saw a red button on the front that was a little pushed out - I pushed it in and I got the led lights back :)
Jun 22, 2009 | Sharp XR-10X Multimedia Projector
Our Whirlpool 27" Built-in Combination Microwave Oven and thermal Oven won't work after self-cleaning model # RM770px882 Serial # XE1401024 Part # 3185651
This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q-- My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
also look for this electric wiring chart given in this link below just click on the link
http://www.applianceaid.com/image/microflowchart.JPG
thanks.
Oct 13, 2008 | Whirlpool Kitchen Ranges
HP VP6210 won´t turn on at all
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Whirlpool LGB6300 Gas Dryer Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
