Question about Sibelius 6 Professional Full Version for PC Mac (724643110758)
My saved sibelious files won't open
Hi guys my saved sibelious files won't open. I believe I caused the problem because in attempting to delete old general files on the computer, due to running out of space, I accidently must have deleted some kind of storage utility without realizing it. Interesting I backed up all my files on a flash drive and if I place any of these files from the flash drive back into sibelious all of the original files reappear in the file location with the light blue and white sibelious logo, however they still won't open. Is there a way I can load whatever is missing back in to be able to read these files once again? If someone has done a similar thing prior and they can help me here I would most appreciate it. Many thanks, cheers Tom.
I have updated my comp and all files were deleted how can i restore them i updated windows vista to windows 7
If it deleted them, you didn't update, you installed win 7 over vista. You can hope it saved all your files in a folder called windows.old I believe. It should be in your C:/ drive.
Mar 15, 2012 | Toshiba Computers & Internet
My nokia e5 stores only 100 sent sms and deletes the old ones , how to make it store more sms and how to recover the old deleted sms ?
Hi there, I'm sorry, but there is no way to have it store more SMS messages, or restore the deleted ones. If you want to save messages, you can use the "save message" option. I don't believe that will count to the 100 you can store in your inbox. Sorry, Alex
Jun 03, 2011 | Nokia E5 Cell Phone
When I am trying to open any saved files in MSWord, I get an error message saying "Windows cannot find example/file.docx. Make sure you have typed the name correctly, and try again." Even when I...
-Run regedit (Start menu, run, etc.) and go to this key:
-Export all the addins to a reg file (for backup)
-Then delete all of them in the registry (or one at a time if you want to
know which addin is causing the problem,
-Now try opening a .docx or .doc file in windows explorer and find that
document loads properly with out any error messages!
-now exit MS Word and open the reg file(s) you exported and import them back
-try opening a .docx file again and the problem is fixed. hope this works for you
May 05, 2011 | Computers & Internet
Rca th1702-a turn on says usable memory exceeded please remove a few files then shuts off not allowing to remove files
Try to remove your unwanted files this way....
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Apr 15, 2011 | RCA Audio Players & Recorders
Deleted can iget it again?
You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted files is to try some file recovery software. Recommended asoftech data recovery as it saved my life many times.
Apr 11, 2011 | Computers & Internet
I am a customer of yours and I ccant keep my computer on long enough to contact you guys....someone was helping me this morning during which time my comouter froze and that was that
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
hope this helps
hope this helps
Nov 26, 2010 | Computers & Internet
Accidently deleted files on sd card with hd writer ae . How can i recover the files?
I had success with steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download sd card recovery software, recommended Asoftech Data Recovery (simply because i was using it and it worked) with link below
SD card recovery software
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your files.
Feb 17, 2010 | Panasonic HDC-SD20 High Definition...
Is there a way to recover deleted files from my sd card on my lg env3
First of all, do not save any new file to the memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this card recovery software called asoftech photo recovery, which recover not only photos, but also videos and audio files from sd card.
Install and open asoftech photo recovery software, select the memory card, and click 'Start' button.
Feb 16, 2010 | LG enV3 VX9200 Cell Phone
How can I launch without recover.c
Look for the answer here:
XLSX Repair Kit. The latest corrupt XLSX file repair software featuring a powerful data recovery core and a convenient step-by-step wizard for extra convenience.
For more information:
Dec 31, 2009 | Microsoft EXCEL 2004 for Mac
For a mistake I deleted some files from my camera Sony Model DCR-SX50E. Can I recover them ?
You may try some recovery software to rescue the files on your recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the handy cam in case the original files(your recordings) are overwritten.
Oct 15, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Sibelius 6 Professional Full Version for PC Mac (724643110758) Logo
55 people viewed this question
Top Sibelius Computers & Internet Experts
Martin Murray
 Russ Hill
Russ Hill
Are you a Sibelius Computer and Internet Expert? Answer questions, earn points and help others
