Question about GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
Not cooling the fan motor was not working i changed it still not cooling
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
uy4
Posted on Sep 29, 2010
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
MY CADILLAC is overheating
if the cooling system is full,it could be the thermostat or the cooling fan not working(fan motor,relay,coolant sending unit,bad connection)or the head gasket is no good or even the computer may not be turning the fan(s) on.when the motor overheats the cooling fan(s) should be running if not that may be the problem.you can have a block test done to see if the head gaskets are bad.chances are you haven`t changed the thermostat so it should be changed at any rate.by putting a scanner tool on it you may find the problem quickly.
Apr 28, 2011 | 2002 Cadillac Deville
2006 bmw 750li, radiator cooling fan not running when engine hot, I have replaced the sensor or switch, in the lower radiator hose with new, fan will not come on still. is there a fuse that might be...
the cooling fan fuse is located in the main fuse panel,location of which should be in your owners manual if you have one if not call the dealer and ask.it could be the cooling fan motor itself not working or the cooling fan relay.to check the cooling fan if you disconnect the plug on the back of the motor and feed direct power and ground to the terminals of the motor.if the fan starts to work then it is okay.to change the cooling fan it is a job for a shop to do as it entails alot parts removal to get to the fan itself
Mar 30, 2011 | 2006 BMW 750Li
My Carrier 43B00HP - 1 is not blowing cool air. The fan is working but the cool air isnt coming out. If you turn it on and leave it on for awhile it turns off by itself
Please check your compressor whether it takes correct amphs. Due to weak in capacitor and also less rpm of fan motor the compressor gets overheated and it turns the unit off. If capacitor weak change it. If less rpm on fan motor change fan capacitor or fan motor.
Dec 12, 2010 | Carrier Heating & Cooling
It has an overheating problem. I changed the
SOUND LIKE COOLING FANS NOT RUNNING CHECK AND SEE DOES COOLING FANS TURN ON WHEN ENGINE OVERHEATS IF NOT CHECK COOLING FANS FUSE AND RELAY IF BOTH CHECKS OUT GOOD HOT WIRE COOLING FAN.IF IT WORKS.PROBLEM COULD BE COOLANT TEMPERATURE SENSOR- PCM- AND OPEN OR SHORT IN WIRES.IF COOLING FAN DONT WORK WHEN YOU HOT WIRE IT PROBLEMS THE FAN MOTOR.
May 27, 2010 | 2001 Chevrolet Malibu
Cooling fan not working
sensor may be bad. . any other symptoms that you think caused the cooling fan to fail?
May 27, 2009 | 1996 Nissan Maxima
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White Logo
219 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
