Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Miele g 646 sc (not plus)
I saw your post about this. My inlet/outlet light keeps going on and the washer won't work. I've cleaned out the outlet pipe and taken out and cleaned the plastic hose with the silver ball in. I can't however find the overflow switch? Can you help?
Many thanks
Jon
Hi I has the same problem, once you have given it a good clean, turn it off put the main dial back to stop. Then put it back to the setting you want press the on switch and then the start switch... It worked for me, had the problem a couple of times now
Regards
Posted on Dec 23, 2010
Check the inlet where it joins onto the tap as mine has a fine filter and debris from the fresh water builds up. Simply remove the pipe from the tap and **** ,this should remove /dislodge any scale etc that could be causing the inlet light to come on. Make sure you spit out the water that comes back from the machine!
Posted on Jul 25, 2008
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
G 646 sc pump still runs when programme is off
I had the same problem, the drain pump kept working even on the off program. After a little investigation i found out that there is a leak sensor that triggers the drain pump continually until it does not "sense" water anymore.
Firstl i tried to open the rear panel with no success.
Next i tilted the dishwasher to the left and let all the water drain out, plugged the dishwasher back to electricity and it worked!!!
I hope it will help you.
Jan 02, 2013 | Miele 24 in. G646SC Plus Free-Standing...
Miele G 646 SC, Leaking.? My Miele G646SC is leaking, the red inlet/drain light is on and I suspect it may be one of the pump seals has perished. The machine is 11 yrs old and has never had a problem of...
The dishwasher must be removed from the counter so you can gain access to the pump. I would check with a parts supply company first to see if the pump is still available, and the cost. It may be too expensive to repair a dishwasher that old.
Removing the dishwasher is not very hard. Turn off the electrical breaker. detach the DW from the counter. Pull out. disconnect the water supply and drain. disconnect power supply if required.
Nov 28, 2017 | Miele 24 in. G646SC Plus Free-Standing...
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
The 'inlet/outlet' red indicator light flashing, small pool of water collected under filter, but cannot get back of to clean it. Model is Miele G646sc
You might be able to reach if you take the sides off. Elect disconnect, open door, remove 2 cross head screws recessed at top of where door closes, push top cover backwards an inch then lift off. remove 2 screws at top of each side panel then the lower ones (4 a side) panels then lift off and you can see right across the bottom of the 'sump' including the float switch assembly. (which has no effect on switching on the inlet/oulet lamp on my d/washer.)
Nov 10, 2009 | Miele Premier-Plus Built-in Dishwasher
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
Aug 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Jul 11, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
506 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
