Question about Casio EXZ550 Digital Camera
On turning it on I get the message "lens error" and won't open or work. Is there something I am doing wrong? Is it broken? Am I not pressing the right button?
  • nigel_fisch Jul 17, 2010
    Lens error on Casio Exilim Z550....keeps coming up. Don't think its been dropped and tried fixes suggested by various web sites. The lens only pops out a centimeter or two so I can't even grab it if I wanted to. I have replaced/recharged the battery but don't have the SD card...would I need that card to get the lens out anyway? Any ideas? It happened a few hours after purchased. My sister bought one as well from a different seller and the same thing happened to hers. But of a coincidence - maybe doing something wrong?
    Quick reply - thanks
  • 10,515 Answers
I am Sorry to hear regarding the Problem.This is a ' Lens Problem ' which is Quite Common on these Models.
It is not worth to get it Repaired, as the Cost of repair would be quite high as compared to the cost of the new camera.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 17, 2010
    Do I need to re insert the SD card to make this work as I don't have it available right now?
  • taran_2005
    taran_2005 Jul 17, 2010
    Thanks for your response!!
    SD card has nothing to do with lens error. Even if you re insert or buy a new one, unfortunately that would not help the situation.
    I could only comment, if that is a new camera, get it replaced unless buy a new one.
    Let
    Hope i helped you.
    Thanks
    Genius:
  • 1,040 Answers
Usually lens error comes when lens retracts mechanism faces some problem, Normally to fix this error cam has to be get serviced.. but still following link will provide more information and some tips on this problem... http://www.brighthub.com/multimedia/photography/articles/39130.aspx
Hope this has helped you... Thanks..
Posted on Jul 14, 2010
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens stuck open on Lumix DSC-TZ5
This is a common problem when something goes wrong with the lens system.
This can be as a result of numerous problems.
Try to pull the lens as turning on and also gently twisting it in and out...just may make the lens go back on track.
Sep 21, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens error message. lens stuck open; gives a lens error message & must remove batteries to turn off
This seems to happen when something (water, sand, dust)
gets trapped in the lens mechanism.
Has the camera been somewhere filthy before?
The recommended methods include taping on the
bottom of the camera,rapping it on a table,
and pressing hard on the lens.
If the lens moves when you turn the camera on,
try keeping your hand on it so that i
t's forced back into the camera body.
A can of compressed air squirted around the
lens is also a possible fix...
but be super careful with that stuff,
a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff
to your camera, but if you're careful you may
be able to get it working again without having
to get it serviced.
Jul 06, 2009 | Nikon COOLPIX L10 Digital Camera
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Lens Error - Cool Pix L6 - Camera unuseable
helppppppppppppppp mne is stuck open and it wrks but whn iturn it off it stays open (1/2 of it)
Jan 07, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Dont know if this will help anyone. I had a lens error for ages. In my long lasting devotion to google serk I found that many equall contenders found that a strike with a soft book in different directiions solved the problem. I ended up beating the camera from all angles with the palm of my hand. But hey! it worked. 4 months later im looking for the cure to system error 2. If you can help wi that one.
Sep 11, 2007 | Nikon Coolpix 5200 Digital Camera
Stuck Camera Lens
You could try the Casio Tech Support team, but if as you suspet it is a matter of dirt- there is nothing to be done except replace the camera- the cost os shippin and examining the camera etc. will come close to its replacement.
Jun 25, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Casio EXZ550 Digital Camera Logo
26 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
