Question about Vacuums
New machine just turned it on water will not come out and brush will not move
  • 1,673 Answers
Consult you owner manual, or take it to a warranty repair shop, you have at least a years warranty on this. Not knewing brand and model, can't help you more.
Posted on Apr 20, 2008
No steam or water even coming out, its just quiet except brushes moving
David, the brushes on the motor may be burned out and the conduction process has been compromised. In short the motor is bound up and won't turn. This can happen if surface debris collect on parts of the motor. Do not turn it on for long and let the unit get warm as it will eventually break down permanently.
If you need a manual, go the company web site and seek that from customer services.
Mar 10, 2014 | Bissell 46B4 Stick Steam Cleaner
Hoover windtunnel V2 Brushes Not Turning
There is a worm gear that turns the brushes, it may be damaged
Aug 18, 2017 | Vacuums
My machine (Hoover Wind Tunnel - bagless) is only 1 yr. old. The agitator brush doesn't turn all the time. I know it's not supposed to turn when in the upright position. However, it only seems to work when...
Sounds like you should do two things: 1- Remove and clean the beater brush of all debris as best you can. At the end of the brush you will see a hard rubber piece, at both ends, that holds it in place in the body of the vacuum. Add some WD40 between the brush and these pieces and turn until they move freely. 2- When you reassemble, put a new belt on.
This should be all you need to do. If you find this information to be of help, I would appreciate a Thumbs Up from you. Be well, Paul
Oct 08, 2010 | Hoover Self-Propelled WindTunnel Bagless...
The brushes won't turn on my hoover steam vac dual v
Hi There,
Unfortunately the answer above is far from helpful. The filter has absolutely nothing to do with your brushes not spinning, and you can really replace the turbine yourself without having to take it into a shop to fix it. Here's a much more helpful diagnosing of how to check the brushes, and fix the turbine if needed.
There can be serveral things that may have gone wrong with your Hoover so that the brushes stop spinning. Unlike the other "expert" above I will walk you through step by step on how to diagnosis this problem, and fix it. Unfortunately there is no belt or band on this model, but instead it's actually a turbine assembly that drives this brush.
Possible Problem #1. Usually the most common problem when the brushes stop spinning is that the brushes have simply gotten clogged with something that is preventing them from spinning. Especially if you have pets in the home, this is a common problem. Here's how you can clean these brushes.
First, turn the machine upside down so that the brushes are facing upwards. Pull down on the upwards on the brushes and they will easily snap right out of the mahcine completely. . Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. It's important to make sure that the brush switch on the top of the machine is turned to "Rotating Brush Speed Hi", and that the handle of the machine is reclined down. There is an internal switch inside the machine that turns the brushes off when the machine is in the upright position, so you'll need to step on the handle release pedal to ensure that this switch is engaged. Hopefully the brushes just needed to be cleaned, and they will now work now that you have reinserted them. If this still didn't fix your problem, move on to the next possible problem.
Possible problem #2: If the cleaning didn't fix your problem, remove the brushes from the machine again. Once the brushes have been removed, the handle reclined, and the brush switch turned to fast, turn the machine on. Where the brushes were sitting you'll see a square shaped hole (pictured below) that the brush stem fits into that actually spins the brushes. This part should be spinning while the machine is on. Here's a picture of that part:
If this part is not spinning, then your Turbine Gear Assembly has gone bad and needs to be replaced. If this part spins however, then this indicates that your brush block is gone bad, and needs to be replaced.
Here are links to the exact parts for your model that may need to be replaced:
Brush Block:
Turbine Gear Assembly:
Here's also a link to a Fixya repair solution that I've done explaining step by step how to replace the turbine gear:
I hope this helped you, please be sure to rate the repair or leave feedback if you found this repair to be helpful.
Thanks so much,
Chris Jones
Jan 12, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
The machine turns on and the indicator seems to be spinning but the water is not moving.
Operating the trigger does not dispense water into the spinning brushes - is that the problem?
If so, remove the clean water tank and look in the opening behind the black grommet that seal the water tank. Operate the trigger and look to ensure that the valve is operating (moves downward when trigger is pulled). If it does not move, the trigger shaft is stuck or broken and will need to be repaired.
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Buzzing noise when machine is turned on
burned up motor. Take it to your local vac shop for a quote on repair or replacement.
May 10, 2017 | Hoover F7458-900 Upright Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
