Question about LG Heating & Cooling
Doesn't work in auto mode
I have a LG LP0910WNR free standing a/c unit with no operating manual. I can't get it to work in the auto mode. It only works as an ''on/off'' machine and I wanted to to cycle down when a certain temperature is reached.
Joe_Rex
  • 114 Answers
SOURCE: AC WILL NOT SHUT OFF
SOUNDS LIKE THE T-STAT TEMPERATURE SENSING BULB IS OUT OF "AIR-FLOW" (SOME CAN COME LOOSE FROM THEIR MOUNTING CLIPS) OR IT IS BAD ALL TOGETHER ... MOST MANUFACTURERS HAVE A ONE-YEAR WARRANTY ON SMALL PARTS AND 5 YEARS ON THE COMPRESSOR .., HOPE IT HELPED.
Posted on May 07, 2007
edgz
  • 26 Answers
SOURCE: ERROR CODE
Hi,Pls to shut - down the unit and try to power on ,may be its malfunction the control LCD.
THANX
Edgz
Posted on Apr 01, 2008
daddyo742001
  • 70 Answers
SOURCE: My LG LAN125 mini split heat pump occasionally
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Posted on Jun 28, 2009
relaga58
  • 158 Answers
SOURCE: Fujitsu Ductless Heat Pump Operation
that's normal
Posted on Oct 14, 2009
SOURCE: I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Posted on Oct 20, 2009
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
How do you add feron to lg lp0910wnr ac
I would suggest taking it to your local service shop. They can add the nedded service valve and add freon.
Jun 06, 2014 | LG Electronics LP0910WNR Portable Air...
How to add freon to lp0910wnr by lg
u dont just "add" it. if it has leaked out you will have to locate the leak and fix it. just adding it it will soon stop working again. are u sure that it is the gas charge? could it be the compressor isnt working?
I get an E1 display and will not turn on
E1 CODE MEANS AIR FILTER IS DIRTY OR THE UNIT NEEDS RESET. IF SO YOU CAN TAKE YOUR VACUM AND CLEAN IT. IF VACUM DOES NOT WORK. WASH IT AND LET DRY BEFORE REPLACING. IF THS DON'T WORK UNPLUG AC FOR A COUPLE HOURS, TO RESET YOUR UNIT. HOPE THIS WORKS FOR YOU
Oct 06, 2013 | LG LP0910WNR Air Conditioner
Why does it turn off and on
Fl means that the water collection tank is full and needs to be emptied. The unit will turn off if it's full.
I could not find the installation manual for your exact model number, but here's one that's similar enough:
http://www.lg.com/us/support-product/lg-LP1111WXR#
It is PDF filetype, so if you can't view it, you need to download and install Adobe Reader on your computer:
You can get the free download here:
http://get.adobe.com/reader/
Sep 05, 2012 | LG LP0910WNR Air Conditioner
How do I drain the water tank in my LG LP0910WNR Air Conditioner
tienes que ver por la parte posterior un tapon de color ***** yquitarlo y luego sacar un corcho de goma y el agua saldra
Jun 12, 2012 | LG LP0910WNR Air Conditioner
LG portable a/c model LP1010SNR and after running for about 15 mins it reads E4
salaams......the unit will stop and display E4, when coil sensor reads temp less or equal to 2 degree centigrade.so deforst it. orrrrr when the coil temperature greater or equal to 8 degree centigrade.its from manual.
Sep 13, 2011 | LG LP0910WNR Air Conditioner
Heating & Cooling Logo
202 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
