Question about HP LaserJet M1522n MultiFunction Printer
I have hp 1522nf printer & it is showing memory low. It is continously showing error 49
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
Hello ! you can try doing the following:
1. Please ensure that the printer is directly connected to wall outlet.
2. Print a configuration page and check the firmware datecode. If possible update printer firmware and check if the issue occurs.
3. If the issue occurs, please perform a restore factory defaults. Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number.
a. On the product control panel, press Setup .
b. Use the arrow buttons to select Service, and then press OK.
c. Use the arrow buttons to select Restore defaults, and then press OK. The product automatically restarts.
4. If the issue still persists, perform a NVRAM initialization. An NVRAM initialization will return the following device settings to the factory-set defaults:
a. Turn off the product.
b. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
c. Wait until the message Permanent storage init. appears, and then release the buttons. When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Posted on Jul 14, 2010
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it. If not I recomend to contact a service center, it could be the formatter (the motherboard)
Aug 30, 2010 | HP LaserJet M1522n MultiFunction Printer
49 error turn power off then on
this is the firmwere error pls turn off the printer up to 30 min then on if problem persiste replace the formatter cart ur problem will be resolved
Jul 14, 2010 | HP LaserJet M1522n MultiFunction Printer
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
Hp 1522nf shows hewelet packard >>>>> at start up and freezes and does nothing only the drum turns a little and thats all and can not use any keys on printer
This problem ussualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model 1522nf will be extended 1 extra year (means you have 2 years coverage) if the printer has one of the issues listed above I Hope this can help You can contact me directly on : eliteprintersolutions@hp.com
Jun 13, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have printernhp 1522nf and lcd show error " ...
The error message 10.1000 as yo can see on the service manual is related to a defective cartridge, basically the printer its not reading the e-label (chip) on the toner cartridge, this could happen because of 3 reasons :
1) You are using a third party cartridge or refilled (there are not supported)
2) The e-label reader on the printer is defective
3) Theres a problem with the e-label on the actual cartridge
Here are 2 steps you can try:
Turn the printer off, take out all supplies out, including paper and cartridges, turn the printer back on and reinstall the all supplies, with this simple steps you can reset the sensors
Whe you take out the cartridge its a good idea to check if theres any little piece of paper that could be blocking the sensors on the printer
Hope this can help you
You can contact me directly :
May 20, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Jan 07, 2010 | HP LaserJet M1522n MultiFunction Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
HP LaserJet M1522n MultiFunction Printer Logo
1,561 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
