I have a ducted air conditioner Daikin inverter model FDYQ250MV1 on the control panel an error appears as ja which is a sensor. I dont know where this sensor is located. This system works during the day. But early mornings when the weather is cold on reverse cycle only the fans work and the power light begins to flash. An error symbol appears as ja.
  • 85 Answers
SOURCE: Heat Pump Stops Working only in the Early Morning
I recommend getting electric back up heat to fix your problem. Like the other gentleman said, defrost is having to kick on too much. It's doing the best it can givin the conditions outside. If you don't have enough power supply for electric back up heat, then a gas furnace or propane furnace will work also, depending on your needs. Heat Pumps are a like a full time fan, they are designed to heat your home at a steady rate unlike forced gas units that turn on extremely high temps and then shut off... Ensure your charge is correct, givin your tempatures the unit sounds to be working correctly, however a second opinion is always a good piece of mind before you spend money on emergency heat.. Hope that helps..
Posted on Dec 02, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
  • 172 Answers
SOURCE: There is a red light on next to the little tap symbol
Unplug and plug in
Posted on Aug 11, 2009
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
Streamline. What does error E0 mean?
How to fault find a Daikin Air Conditioner, troubleshoot split ...
? 4:22
www.youtube.com/watch?v=i30rEvyuDKs
Feb 10, 2012 - Uploaded by Fully Airconditioned This video shows how to get fault code from remote control and reset fault, you ... Daikin Inverter AC Unit Fail - Moisture / Salts Damage to PCB ...
Sep 30, 2015 | Inverter Heating & Cooling
I have daikin n81 air con, its showing f3 code on the control panel what dose this mean
f3 error is a bad thing, it means excessive compressor temperature in outdoor unit. Overheat condition outdoors. Please find a daikin factory authorized service tech in your area to come check it out. These units are awesome when they work, but when they don\'t, normal HVAC techs tend to not want to touch them. They will try to sell you something else. Or even worse, they want to vacuum and refill them for no obvious reason. A 200 dollar maybe fixit.
The daikin units work more like a tv or a car than the old school air conditioners. They have remote controls and service menus and scan tools and such. A veteran daikin tech can diagnose your system fast and give you a wise estimate of what you need. You may just have a leak, or there might actually be something mechanically wrong outdoors.
I would not push my luck and try to run the unit with this error code. Please don\'t let the magic smoke out of your system.
please mark my answer helpful.daikin ductless
Jan 04, 2015 | Heating & Cooling
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
Nov 10, 2014 | Cfm Daikin R410a Split System Air...
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Lost manual for model R410A Daikin invertor. Where can i find a new one?
google daikin (model number) manual . what are you trying to do or just want a manual ?they really dont tell you much in them.
Nov 03, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
