Question about Canon PowerShot A80 Digital Camera
No image on the viewer; no image being recorded.
There is no image on the viewer and the camera is not recording images (batteries are fine, memory card is fine).
  • 10,594 Answers
If your Canon A80 camera shows previously stored images of memory card in playback mode but does not show live view in camera mode to take fresh picture then ccd imager chip got defective and need to be replaced.
Local camera repair shop will help you to replace ccd imager chip because camera will take apart in detail and soldering work is needed.
Thanks.
Posted on Jul 14, 2010
My finepixZ20fd says ''images recorded to internal memeory'' and won't transfer the photos to the computer when the USB is connected.
The message "images recorded to internal memory'' is just a warning, that there is no memory card in the camera. It doen't necessarily mean that there are any images saved in the internal memory.
The message should rather have been "images will be recorded to the internal memory"
Feb 08, 2010 | Fuji Finepix Z20fd Digital Camera
Optic viewer blurred image
Not much that you can do with that, try adjusting the small focus lever on the underside of the viewfinder, as this might fix the blurred image, your lucky that you didn't, break something on the camera.
Jan 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
SD Memory Cards to record in MPEG2
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Storage path
On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
Aug 31, 2005 | Panasonic iPalm PV-DC3010 Digital Camera
Storage path
Aug 31, 2005 | Panasonic iPalm PV-DC3000 Digital Camera
Record in MPEG2
Aug 31, 2005 | Panasonic D-Snap SV-AS30 Digital Camera
Record images
Quality Mode Resolution 14MB Internal Memory 256MB xD Picture Card 512MB xD Picture Card SHQ 2592 x 1944 3 images 69 images 139 images HQ 2592 x 1944 11 images 204 images 409 images SQ1 1600 x 1200 27 images 515 images 1030 images SQ2 640 x 480 144 images 2663 images 5324 images
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Video and still image - SD Memory Cards
Aug 31, 2005 | Panasonic D-Snap SV-AS3 Digital Camera
Canon PowerShot A80 Digital Camera Logo
676 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
