Question about HP Photosmart R717 Digital Camera
Digital camera R717 - display screen
While on vacation, i turned my camera on from charging the battery over night, and the display screen was all grey and full of lines. if i try to check what flash setting it's on, or check to see any of the settings, i get the same screen. i cannot see any of my previously taken photos or what photo i am trying to take at the current moment. i've tried resetting it but that doesn't help. any suggestions would be appreciated as the camera is pretty much useless to me without the display screen.
  • 1 more comment
  • Joziesmama Apr 20, 2008
    sorry, didn't work. still get the grey stripes with no response from pushing any of the settings buttons. joziesmama thanks you for your time.
    hp photosmart R717 6.2 megapixels digital camera - model FCLSD-0505
    still no luck -
  • 156 Answers
CHeck out this link it might help
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Posted on Apr 20, 2008
    Genius:
  • 1,447 Answers
Try to power cycle camera, turn it off then remove battery and memory card for 10 mins and reinstall memory card and battery back. turn it on... update me
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 21, 2008
    I think the motherboards has gone bad may be due to overcharging the unit and the cause can be due to heat generated overnight and has damaged some component of the motherboard,
    Try to get hold of a service technician and get it repaired or you can simply call hp and ask for help
    contact HP
    Before that you can give a last try to these steps
    HP Photosmart R707 and R717 Series Digital Cameras -
    Performing a Power Reset
    Resetting the
    camera can correct many issues, such as the camera locking up or not
    turning off. The reset drains the power and, in some cases, causes the
    camera settings to revert to factory defaults.
    NOTE:
    Resetting the camera returns all settings to the factory defaults. Any images or video clips stored in memory are
    retained.
    Perform a power reset of the camera
    Obtain a paper clip, locate the reset switch, and then follow the steps below to reset the camera:
    1. Turn off the camera.
    2. If there is an optional memory card in the camera, remove it.
    3. Remove the battery from the
      camera.
    4. Press and hold the straightened end of a paper clip in
      the reset switch. Release the switch after three to six seconds.
      Figure 1: Camera reset switch
      NOTE:
      The Reset switch is the small hole located by the
      battery slot.
    5. Reinsert the battery and close the Battery/Memory card
      door.
    6. After verifying that the camera works without an optional
      memory card, reinsert the card, if desired.
      NOTE:
      If
      the issue is not resolved, try using the camera without a memory card
      or format the memory card. This will help to determine whether an image
      on the card, the card itself, or the camera is causing the camera to
      lock up or preventing it from turning off. See the camera User Guide
      for formatting instructions.
  • Maanita Chadha
    PLEASE LET ME KNOW THE STATUS AND DONT FORGET TO RATE FIXYA .
  • Maanita Chadha
    Refer to this link:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
Turned my phone off for a weeks vacation, and now it will not turn on
The battery threshold voltage has gone BELOW the mark required to display anything on the screen. So connect the charger and let the phone charge over night as the display will come on. You can also check the voltage on the battery to confirm this and so put it on for charge.
Jun 14, 2011 | Cell Phones
HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
Nov 29, 2009 | HP Photosmart R717 Digital Camera
When I turn on my HP R717, it won't stay on!
You must replace the batteries. This is a very common problem with all digital cameras. They require a massive amount of power. They will shut off as soon as there is insufficient power to run them. Try rechargable lithium 2400 batteries, they last the longest in digital cameras.
Jun 28, 2009 | HP Photosmart R717 Digital Camera
HP R717 camera will not work . installed new battery will not charge
Connect the camera to the charger. If it works, while connected to the charger, the problem is either with the battery or the battery contacts. Make sure that battery contacts are clean.
Apr 23, 2009 | HP Photosmart R707 Digital Camera
Broken lcd P R717
you can find part on Ebay under cameras for parts or repairs. Look r717, but also look into m305, m307, m407, and m417 cameras. They all use the display screen.
Dec 27, 2008 | HP Photosmart R717 Digital Camera
HP R717
dear mkmkmk,
The easiest way to get rid of the date time stamp with a broken lcd screen is to do a mual reset of the camera, which can be done by
1. turn of camera
2. remove memory card
3. remove battery and make sure the ac power cord is not connected.
4. you need to press the reset switch which is located above the battery slot. To do this you need to get a paper clip and straighten it and push the straighted end into reset switch until the switch is depressed.
5. reinsert the battery.
6. after you verify that the camera works without the optional memory card reinsert the memory card.
the factory setting default does not have the date/time stamp activated.
Sincerely,
Agent Allan
Go Ahead. Use Us
Apr 15, 2008 | HP Photosmart R717 Digital Camera
Camera will not switch on
my camera will not show power when plugged into the dock, I had power from this before. Is it the dock or my camera that isn't working properly? Thanks Joanie October 2,2008
Feb 25, 2008 | HP Photosmart R717 Digital Camera
Black Pictures
Do you have it in manual mode with too small an aperture and too fast a shutter speed?
Sep 12, 2005 | HP Photosmart R717 Digital Camera
HP Photosmart R717 Digital Camera Logo
460 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
