Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Botton door sticking hard to open and close
Bottom door sticking and hard to open and close dishwasher still works
  • Fisher and P... Master
  • 3,247 Answers
It is likely the drawer seal assembly is not working properly.
You will have to get the drfawer out from the housing and check the top inside of the housing to see if the seal is broken or can be more complex if the seal actuator motors are out of alignment. Will need to call technician if you are not familar with electrical components.
If you keep operating like this then water leak can cause damage to dishwasher.
Posted on Jul 30, 2010
My Dishwasher door keeps springing open - how do I fix this?
seems like it should have a lock on it someplace to keep door shut while operating .
May 16, 2015 | Dishwashers
While the washer is on and the water starts the door opens how to fix this? thanks
Hello Shirin;
My name is Peter. I am a retired field service appliance technician.
Push in the top and bottom trays. Close the door. Now, open the door. Are either the top or bottom trays pushed out?
In the bottom center is your water distribution vanes. Are they stuck up in the operating mode? Push the center water distribution vane down, push the top and bottom trays in, close the door and reopen. Are the upper or bottom tray sticking out? inspect the guide rails. Is there something blocking them?
So, your problem is:
1.) The trays are pushing against the door because they will not go in all of the way.
2.) You have a broken latch assembly.
You did not provide a model number. This is on a tag either on the top of the door or on the face of your dishwasher after you open the door
May 16, 2015 | Frigidaire Dishwashers
Kickplate on model KUDG25SH
turn off breaker to it leave one minute and turn back on also make sure door is closed tight and nothing is fouling it from proper closing .
Jul 13, 2014 | KitchenAid 24 in. KUDS01FLBL Built-in...
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Dishwasher wont work - starts but then stops and the light flashes. Have tried cleaning it out but dont know what else to look for?
Hello, Try this Crack the door open and then hit the following botton combination high temp wash - heated dry - high temp wash - heated dry then close the door and hit the cancel button. wait for the pump to stop. Hope this helps! Mike
Jan 05, 2010 | Whirlpool Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Starting botton does not work
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 25, 2009 | Whirlpool Dryers
Detergent falls out and doesn't melt
check water temperture its not hot enough..onthejob
Feb 05, 2009 | Dishwashers
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Dacor dishwasher door won't latch
Don't know if this helps or not...might be obvious...if you open the door and look up where it latches...there is a philips screw you can loosen to adjust the latch forward or back.
Nov 22, 2007 | Dacor ED24 Built-in Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
141 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
