Question about Cisco (1841) Router (cisco1841)
Hi i have 1841 router what is the default user name password for this i tryed with user name passowrd as cisco but is saying that no user cisco pls help me
  • 30 Answers
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Posted on Mar 01, 2011
Garbage in Cisco 1841
There are two things that can cause this:
  1. Incorrect serial settings. The default settings are 9600 baud, stop bits of 1, and parity 0. However, it is possible that these settings were changed. Likely, the baud setting may be higher as someone may have tried to XMODEM an IOS image onto the device and wanted faster speeds.
  2. Bad connection, cable
I hope this answers your question.
Jan 06, 2012 | Cisco (1841) Router (cisco1841)
What is the default enable Password for cisco 7604 - sup720-3b
The default user name and password for Cisco routers and switches is usually:
user name: Cisco password: Cisco
Make sure to capitalize the C's.
Mar 16, 2011 | Cisco 7604 Chas 4-slot 2 SUP720-3B 2 PS
I forgot to change the default public credential User: cisco and pwd: cisco. Un fortunately I did restart the router. I would like your assistance to gain access to the router or to reset it back to...
Here is a cisco page that goes over the password recovery procedure. Once you reset the credentials, you can make any configuration changes needed. You will also have the option to keep the existing configuration in place but change the password, if the configuration has any use to you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Mar 11, 2011 | Cisco (1841) Router (cisco1841)
How can i change my wireless router password??
Reset the router then it will revert to the default login and password.
Then connect up to the unit via Ethernet and using a browser you type in the address in the address bar and then you will be asked for the login and password, after which you can set up your router.
http://www.cisco.com/en/US/docs/routers/access/1800/1841/hardware/quick/guide/1800qsg.html
Please go to this website above and it has all the information there for you.
Aug 06, 2010 | Cisco (1841) Router (cisco1841)
Cisco VPN Issue
If you are using the firewall feature set on the 1841 then make sure, you have all permit statements right and nonat statements in place. Try command line as well and go over some router to router example configs from Cisco's website
Jun 13, 2009 | Cisco 1841 Advanced Security Feature Pack...
WRT300N password lost reset? no software
Reset the router as factory setting,after words you can change the password OR Just try the user name ---root & password is password.
May 18, 2008 | Cisco (1841) Router (cisco1841)
Cisco (1841) Router (cisco1841) Logo
685 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
