Question about Whirlpool Dryers
Flame on gas dryer comes on but does not stay lit?
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Posted on Jul 14, 2010
    President:
  • 2,468 Answers
One of 3 issues,1st-the high limit or cycling thermostat could be weak and opening 2nd-the radient sensor eye can be bad or dirty,try cleaning first,both of these are on the burner tube side, 3rd-the gas valve boost and secondary coils could be weak and not holding the gas valve open to let the gas flow,these coils are on the gas valve top body
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
The igniter heats and the flame lights, but it shuts off after just a minute or two. It won't go back on until the dryer has cooled down completely. Could it be the high-limit thermostat? With the...
What your describing sounds pretty much like the sympthons of weak coils that open the gas valve. It is a fairly common thing that happens with gas dryers so i have written a tip that explains in detail what happens when gas valve coils are weak.
http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
I hope i have helped you to fix your dryer,
GENE
Oct 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Maytag gas dryer - model unknown - gas wont stay lit
Yes does sound like blockage in the exhaust vent causing the high limit switch to stop the dryer.
Mar 26, 2009 | LG DLG5932W Gas Dryer
Gas dryer flame won't stay lit
Check for a blocked vent.
Mar 12, 2009 | Amana Dryers
Dryers Logo
80 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
