Question about Parrot CK3300 GPS Receiver
Pairing LG Shine phone with Parrot ck3100
Was able to pair phone with Parrot, however my phone book directory is not available thru Parrot. How do I resolve this?
Thank you,
  • 1 more comment
  • janpw Jun 20, 2008
    I have a TREO 755 and can't seem to pair it with the Parrot CK3100. It won't download my phonebook to Parrot. What do I do????
    Thanks
  • Anonymous Jan 08, 2009
    HI i HAVE FORGOTTEN THE PASSWORD FOR PAIRING MY pARROT CK3100
  • Anonymous Mar 23, 2014
    Where is the Parrot device and what does it look like?
PREVIOUS PROBLEM:
PASSCODE IS: 1234
Posted on Jun 21, 2009
  • CLARK1611 Jun 21, 2009
    From your phone
    * Select MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / PAIRED DEVICES / OPTIONS / ADD NEW
    * Select 'Parrot CK3x00'
    * Enter 1234 as PIN CODE
    * Select OK
    * You are now paired with the car kit.
Call Safewireless.com, they helped with my problem even though I didn't buy my Parrot from them.
Good company that knows their product!
Posted on Sep 13, 2008
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
Carnt pair phone with ck3100
go to settings then paried devices and delete all the previous paired devices, the parrot will only hold 5. if this dos'nt work you may need to perform a software update, this requires downloading new software from parrot.com/support and sending via bluetooth to your parrot. check parrot site for compatability with your phone.
Mar 04, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
HI my parrot has doubled up on some of my contact numbers in its memory and calls them v card and some numbers in the parrot dont match the phone ie i call janet on the parrot and on the phone (samsung G...
The question is to know if you have the auto sync of the contacts to the kit?
Sometime, with some synchro, it inverse name and surname.
But sometimes a piece of the directory is synchronized via the auto synchro.
In that case, you will have to use the V card, then sending either one by one or the whole phonebook.
But you will have to rebuild the pairing between the mobile phone and the kit (first you delete the pairing and then you rebuild).
But you will have to block the sync, then you will use tot the kit settings- advanced settings pair the phone and then select the menu without synchro.
When you will send the contacts after the pairing, you will have to get the phone and the kit disconnected during the process and reconnect when the phone book are on the kit.
Nov 04, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Cannot pair up n95 with parrot ck3100
you willhave to send the contact manually to the parrot you can try making all but if this dont work you will have to send them one by one.
Oct 23, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Memory full on Parrot CK3100
turn ignition on in car push and hold green and red buttons together fro 10 seconds, the kit will say memory erasing in progress, then please pair device, then pair phone..
Sep 06, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
Pairing with lg phone
The display should read "Goodbye" when turning the car off. Try switching the inline fuse holders. (Orange and Red Wires)
Jan 09, 2009 | Parrot CK3300 GPS Receiver
Parrot 3100 LCD Phone book problem
go into phone book, select mark all then send as a business card to parrot.
Jun 15, 2008 | Parrot Hands-Free Car Kit with LCD Display...
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Mar 11, 2008 | Cell Phones
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* The phone will search for available devices
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Parrot CK3300 GPS Receiver Logo
498 people viewed this question
Top Parrot GPS Experts
George Merkley
George Merkley
Vladimir Frolov
Are you a Parrot GPS Expert? Answer questions, earn points and help others
