Question about Frigidaire GLWS1233A Top Load Washer
Water doesnt stop running in machine
No matter what setting the machine has water continues to run in to overflowing and therefore does not agitate on wash or rinse the spin cycle works when set maunally
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Jul 14, 2010
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Washer tub overflowing on GE Profile WPSE4200A0WW no matter what level is set to. what test can I run to determine what component requires replacement. i have run the machine with no items in the washtub...
If you live in an area where the water is hard check the rubber hose to the barometric pressure switch. If it is loose from the tank or clogged(more likely) it will cause overflow. With the machine filling unplug the power cord, if water stops the water valve is good. The line to the baro switch connects to the back of the water level(baro)switch inside the control panel. Remove the plastic ine from the baro switch and blow down it like you are trying to fill a baloon. If you can not blow down it then it is clogged and you will have to unhook it and clean out the end where it connects to the tank. If it blows out ok then find a short pice of rubber hose connect one end to the baro switch, turn to lowest water setting and blow on it like before you should hear the baro switch click. If it dosent then it will need to be replaced.
Oct 10, 2009 | GE Profile Prodigy WPSE4200A
Water overflowing - GE wvsr1060a1ww top loading washer
since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Aug 16, 2009 | GE Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
