We recently moved to a new house and have lg room thermostat controls but no manuals(former owners did not provide) I tried looking for the control online but the nearest one is lg PZRCUSB0 Accessory
  • 57 Answers
SOURCE: remote control for a/c
If you have the manufacturer name a model number and serial number . You can usually find a web sight on line for that manufacturer. Go to the sight, find a contact phone number, call them and explain your problem. Most times they will either give you a web address that will have the information your looking for or they will send you a copy of such information.
When ever in doubt go to the source.
The Manufacturer name and model should be on a tag somewhere on the front of the unit. It could be under the cover though.
Posted on May 17, 2008
SOURCE: danfoss thermostat control frozen at
See the link on the Danfoss site.  This has helped me http://heating.consumers.danfoss.com/xxNewsx/5dbcb2f9-e888-4d2d-9761-7470786749c9_CNP1.html
Posted on Dec 09, 2008
  • 400 Answers
SOURCE: Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
Posted on Mar 05, 2009
james3751
  • 614 Answers
SOURCE: Setting Amana Heat Pump Thermostat.
The 2H/1C is one stage cooling two heating. Is it s touch screen or not. I mean no buttons. If not go to mode setting. Push mode till you get to heat not emerency heat abd then set temp. Keep in touch. Rus
Posted on Nov 19, 2009
tunde007
  • 2382 Answers
SOURCE: hi, i have moved to
Hi, you can get and download the user manual on this LINK......
You can also call Eberle on this number +49 (0) 911 56 93-0 to make a request for the copy....
Posted on Dec 03, 2010
No matter what setting is put on furnace humidifier, moisture forms on windows.House is only 6 years old and does have a lot of windows.
Hello WPwilkers, Well there's good news and good news!
First off, you should probably use the lowest possible setting as your house being so new, is likely pretty "air-tight" and as such, doesn't have a lot of air infiltration (gaps and drafts) hence the reason you're seeing moisture on the windows.
Now, I would also use a hygrometer, just like your parents likely had hanging on a wall somewhere in their house. It will give you a better idea of the moistur (humidity) around the house. My guess is that you're already at the 60%+ level of humidity.
I suggest that you turn "OFF" the furnace mounted humidifier, until you no longer see moisture on the windows. That will allow the house to adjust and get back to normal humidity levels.
Then you can start by setting the humidifier on the lowest possible setting and keep an eye on the moisture levels in your coldest room of the house, as that is where you'll first notice the excessive moisture on the windows (just the way it works - cold rooms get condensation on the cooler windows first).
If you don't have the humistat (the control for the furnance mounted humidifer) mounted next to your heating and cooling system thermostat, you should do that - it will make it easier to adjust and also will provide a more accurate reading for the humifier to operate properly.
Some Thermostats have the ability to add a humidifier on it for integrated controlling of the furnace humidifer. Check your Thermostat and Furnance owner's manual for details.
I used to have the same problem and found that by moving the humidifer control from the utility room (mine was in the basement of my house) to the living space, it made a big difference. Since most people's homes have unfinished basements and that's where the HVAC system is located, it doesn't get the same humidty readings as an occupied living space.
The other reason that you tend to get moisture (condensation) forming on windows is that the Percentage of humiditfication is set manually with the humidifier control, and yet, the outside (and inside) air temperature vary and the difference between them can cause the humidity levels to go from very dry to very moist, in a day or two.
I tend to wait until I notice that the air inside the house is getting dry and then turn on my humidifier, once the cold winter days have taken hold. In summary, nothing wrong with your unit, just mother nature and a well built (most air-tight) home are giving you higher levels of condensation than most older homes. Gradual adjustments, once you turn the humidifier off for awhile, should get you the desired results.
I hope you find this Very Helpful and best regards!
Dec 17, 2009 | Honeywell HE365 Humidifier
York Gas Furnace Model # P2MPD14N08001A - Combustion Air
where are you getting combustion air from now in the midwest 1sq" per 1000 btu York.com with the model number
Jun 16, 2009 | Heating & Cooling
No Instruction manual
This is for APAC
corp.carrier.com.au/content.cfm?content=111 -
This is for; Hotpoint
://www.geappliances.com/service_and_support/literature/
May 28, 2009 | Heating & Cooling
Spoke with independent contractor - he told me how to set the timer
Done thru mate at no charge
Cheers
John
May 28, 2009 | Carrier Heating & Cooling
Jan 21, 2009 | LG LSC121PMA Split System Air Conditioner
AC wont shut off
while unit is running tap control to see if it shuts off or turn therm. up to 80 if still runs replace control (warranty)
Dec 14, 2007 | Fedders AEQ07FBG Air Conditioner
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
