Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Ice maker Is there 2 types of ice makers for this refrigerator? Pulled the cover and can't find the screw you referred to.
  • fengine5 Apr 24, 2008
    fixum1's solution cured the frustrating problem we had with our ice maker. Thanks, so much.
    Genius:
  • 1,073 Answers
No the little screw is very small and it is on the black part of the ice maker module on the right side of the module
you will see a large white gear look to the right side of the module and you will see a small hole where the white screw is located
Posted on Apr 20, 2008
Ice maker makes ice but don't dispense ice or water
Hello Greig;
My name is Peter. I am a retired field service refrigeration technician.
I do not know what type of ice maker you have. Some have wire arms on the side, some have a downward plastic curved arm and some have a paddle arm on the side.
Some ice makers when they harvest have a plastic ice mold that rotate and flex, others have a little heater that heats the mold then activates finger arms to rotate and sweep the cubes from the mold.
Bad Sensor? All ice makers have temperature sensors. The sensor activates the harvesting of ice cubes when it senses the cubes are frozen. On some plastic ice cube molds it is a white wire on the bottom of the mold. On the cast steel molds the sensor is in contact with the mold at the front end.
Bad Motor Module? All ice makers have a motor module. The module has a control board and plastic gearing for the motor with in the module. The motor module is the assembly in front of the ice maker. The motor module tells the water valve when & how much water to fill the mold. It tells the mold heater, on the cast steel molds when to turn on after it reads the temperature sensor and then it tells the motor when to start rotation.
Not all ice makers can be repaired. Most are solid state.
The ice maker with the cast steel mold can be repaired. Remove the ice maker - Unscrew the one screw under the ice maker. Loosen the 2 screws on top so you can lift up and remove the ice maker from the wall. With a small screw driver wedge in the wire harness connector to free the icemaker. Pop the front cover off (No screws). Unscrew the 3 screws on the motor module and remove. This part is replaceable. Inspect for Burn marks and broken gearing. Unscrew the 2 screws to the heater and mold assembly to access the sensor - this is replaceable. There is no way to test this sensor.
Nov 01, 2014 | Frigidaire Refrigerators
Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Jul 07, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do I remove the ice maker from the refrigerator?
Hello there,
To be able to remove the ice maker from the refrigerator, please follow the steps below:
  1. Unplug the refrigerator ffrom the power outlet,
  2. Open the door and unscrew the screws that mount the ice maker, there are basically 2 screws, for some model, there is a screw under the mounting that is holding the ice maker in place, but make sure you do not loosen the screws completely,
  3. Lift the ice maker up from the screws mounting it and pull it out from the rear of the refrigertor,
  4. You will have to squeeze the tab on the wire connector in order to remove it from the refrigerator wire harness.
  5. Then you can remove the ice maker.
That is how to remove the ice maker from the amana refrigerator.
All the best. Elect_Comp
Sep 20, 2011 | Amana AFF2534FE Bottom Freezer French...
Ice maker control arm has broken and ice machine keeps making ice. How do I stop the icemaker? And, then, how do I fix or replace the control arm (which appears to have snapped at the point that the arm...
Good day,
You will have to remove the ice maker. Usually 2 screws or clips on top and one screw on the bottom, as well as the plug that supplies the electrical power.
Since you'll need a new arm anyway, I would suggest you take the ice maker to any decent sized appliance parts house, and see if they'll pull the the old stub out and install a new control arm.
If that doesn't work, you'll need to replace the whole ice maker.
If you want to see if you can remove the stub yourself, unsnap the front cover. You'll see a semi-solid state type board. It is held in with 3 screws. Remove those, pull the board off, and inspect the area we are talking about. You might be able to get it out, but if not, go back to my first suggestion.
Oct 11, 2010 | Amana ARB9059CS Bottom Freezer...
Need to replace Ice Maker in bottom freezer
Good day,
3 screws hold the ice maker in place. On some versions the 2 top screws are replaced with clips, but it is self explanatory.
The cover is a tight fit, but un clips from the bottom first. You re-install by snapping it in place with the palm of your hand.
The wire pulls straight out of the front of the ice maker and then you wiggle the rear off its mounting hole.
HOWEVER,
What you described is classic of a bad water valve. Especially the overflow issue. I would change the valve first, and if it still has issues then replace the ice maker.
Apr 07, 2010 | Amana AFD2535DES French Door Refrigerator
We have a KitchenAid side by side Refrigerator Model KSRG22FKWH15 with style 2 ice maker. Have water but ice not being made. Have checked all normal reasons for not making ice. How do I remove ice maker...
try this:
1. Remove the bucket from the door to get some room.
2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
4. Remove the screw in the right rear bottom side of the ice maker.
5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
6. On the left track the should be a tab toward the bottom which you need to push up.
7. Push up tab and start working the ice maker towards you pulling it out of the track.
8. Careful with the electrical harness in the back as you're pulling out.
9. Disconnect the electrical plug by lifting the clip on the plug.
10. Remove the side cover on the side module by pulling off.
11. Remove the bottom shield by removing the 3 screws on the bottom.
12. To install reverse the order as it came out.
Apr 02, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker is over filling
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Thanks
Aug 12, 2009 | Whirlpool Refrigerators
Ice Maker Overfills With Water
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker isn't working
the fingers should "normally" be in the 2 o'clock position facing the front of the icemaker. what we need to do is remove the front cover of the i/m look at the big gear in the center of the gear should be 2 clips that hold the gear in place. sometimes this clips will either break off or become compressed and then it doesnt allow i/m operation. the part is very easy to replace your self you need pt#8201515 that can be purchased thru a local appliance parts supply house or online thru  some place like sears.com. good luck peyton..
Jan 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not getting water Kenmore Side/Side 53642
2 things that could be wrong with these ice makers (Red light is solid, but no water to ice maker and My ice maker does not make ice and water is appearing on the floor). Either you have a defective water valve or your incoming tube is iced up. 2 ways to check:
1. Check your ice maker valve which is at the bottom of the refer. To find follow the water line into the back of the refer. it should connect to the water valve. Check and make sure there is 125V to the valve when it is in fill mode. Or look for and open condition at the solenoid (you check for open with a meter). When checking across the leads you shouldn't get any meter movement at all.
2. Remove the ice maker or the port that comes into the ice maker on the back of the refer (it is usually held in with 2 screws). Make sure it is not frozen up. If it is sometimes if you take regular insulation and pack it into the area where the port comes in that can stop the freezing problem.
Good Luck!
God Bless
Oct 23, 2007 | Kenmore 53642 / 53644 Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
