Question about Saniflo & Saniplus& Macerator Pump
The saniflo keeps cutting in even when not flushed
The saniflo just comes on itself .Then it stops and then starts again about half hour later.
Switching off main switch stops the problem but does allow us to use the loo when needed!
    Scholar:
  • Saniflo Expert
  • 115 Answers
Water pressure makes the unit kick on and off. It will turn on by itself if water is somehow draining back into the pump. It could be water leaking from the toilet tank into the bowl and from the bowl to the pump or the flapper on the check valve inside the discharge elbow may be stuck open or could be defective and allowing waste water to drain back into the pump, once it builds up enough water pressure inside the pump, the unit will kick on and off by itself.
Posted on Jul 27, 2010
  • 25 Answers
Hi, sounds like there is a blockage in the unit the unit should be easy enough to be removed and check the inlet and outlet for any obstruction or try poring hot water down the toilet sometimes the hot water is enough to break up papper blockages
Posted on Jul 14, 2010
Saniflo compact part flushes when being used
Of course you should , the MAKER should make it right
May 22, 2017 | Home
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
We have a saniflo. We were out, and our babysitter (who isn't familiar with saniflos) was in the bathroom and suddenly she said water was flooding out of the toilet - she said she had heard a loud noise...
If the apple core was right at the pump intake at the time the pump kicked on it very well may have been the problem. The pumps in those units are not the strongest in the world anyway. They are not made to grind up anything that has any bulk to it.
So the answer to the question in my opinion is yes. But you well want to keep a close eye on it for a while.
Mar 11, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My 1993 Buick Century has trouble starting occasionally. After having it towed once when I wasn't able to get it started after about 30 minutes of trying, it started right up and continued to keep...
OK FIRST THING IS THE DIES AND WONT START FOR HOURS REPLACE THE IGNITION MODULE AND IGNITION COIL THAT WILL TAKE CARE OF THAT THE PLUGGED PROBLEM IS A BAD CAT CONVERTER ON THE EXHAUST SYSTEM REPLACE THAT AND YOU WILL HAVE POWER AGAIN THAT WILL MORE THAN LIKLEY TAKE CARE OF THE OTHER STALLING PROBLEM TO
Oct 18, 2010 | 1993 Buick Century
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Sony Walkman MP3 keeps turning itself on.
Mine is the opposite. It keeps turning off... Stupid piece of ****. A person here tryin to buy a quality mp3 player and it's worse than the cheaper ones... Bah.
Dec 29, 2009 | Sony Audio Players & Recorders
When flushed pump starts water goes but pump keeps running when level is reached
pump keeps running - again this is indicative of a dirty / scaled saniflo. You need to clean / descale the saniflo. if this does not work then an outlet pipe blockage (22mm) may have occurred (unlikely if the unit is operating ok). Saniflo sell their own cleaner, which can be introduced via the wc bowl. If this does not work, then its time for a proper clean ( remove unit, jet clean, acid descale, wash, replace). Obviously not everyones cuppa tea.
Oct 27, 2009 | Saniflo & Saniplus& Macerator Pump
Pumps for a few seconds then stops & pumps again for another few seconds & so on
The toilet will flush normally and shut down. Then imediately after it has shut down, as it should, it will start up again and keep going through the flush cycle until I unplug the power going to the pump. After about ten minutes, I can plug it back in and it then will not start up again until I press the flush button.
Jul 01, 2009 | Saniflo Sanibest macerator with multiple...
System not flushing and motor cut out.
Motor may have been jammed and notw burned out.
May 29, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo works in short burst when not flushed eg in night
Sound to me that the toilet is over filling and in doing so water will over flow down the pan. This is definately what I would check first!
Jan 27, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
777 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
