Question about LG Washing Machines
LG 7kg Front Loader not emptying fabric softener tray
Washer proceeds through all wash cycles but on completion the fabric softener tray has water in it. Fabric softener has gone but tray has to be sponged out before next load of washing can be done. Washer is not 12 months old and has been doing this for about one month now.
SOURCE: Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Posted on Aug 05, 2007
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
Posted on Apr 11, 2009
57 varieties
  • 1653 Answers
SOURCE: Fabric softener doesn't leave the dispenser
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
SOURCE: remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Posted on Jan 09, 2010
SOURCE: kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Posted on Apr 18, 2010
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
GE Front Loader will not despense Fabric Softener
We checked the cold water line that goes into the washer, it had some pretty nasty stuff in it, and once we cleaned it out, and soaked it in CLR, it cleared up the line. Once we reattached it and ran a cycle, it went great. I am assuming with the line being clogged it didn't have enough water pressure to flush out the fabric softener.
Apr 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
