Question about Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
  • 43,501 Answers
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Posted on Aug 27, 2010
I have a 4340 makita jig saw with a keyless chuck and I have a blade stuck and can't get it out . Any suggestions
push the collet retainer hard up on the shaft and the broken bit will fall out
Apr 09, 2017 | Makita Saws
How do I remove a sawzall blade in a ten amp Milwaukee that's flush at the keyless chuck?
Take the clamp apart by removing the spiral ring that holds the collar on and then remove the pin. Make sure you write down how to put it back together! Once you remove the pin everything else will come off easily! diagram the whole thing as you go!
Nov 04, 2014 | Milwaukee Tool Saws
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
I have a sears reciprocating saw with a broken blade.I can't remove the busted blade.Is there any way of removing it?
heatman101
Aug 19, 2010 | Craftsman Saws
Reciprocating saw problems cannot get broken blade out of chuck
heatman101
Aug 15, 2010 | Dewalt Saws
Pin and lock where the blade is come off and giving me a hard time putting it back
heatman101
Aug 15, 2010 | Skil 9.5 Amp Orbital Reciprocating Saw...
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Blade not releasing
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
VULCAN RECIPRCTING SAW
heatman101
Jan 08, 2009 | Vulcan Pwt 18V Rs 18V Cordless...
Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw Logo
1,205 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
