Question about Maytag M3X05F2B Air Conditioner
Dripping water noise in A/C
My unit after running for a few hours sounds like a waterfall inside. Water seems to be moving around, but I never see any. Rarely, unless it is very humid outside, does any water drip outside from the unit. Any thoughts?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
Yes, your ddrain holes are plugged and it should be,a ccording to plumbers standard slopped away from the building at 1/4 inch per foot in order to properly drain. Or else you will end up with a mold machine. I'd put a teaspoon of bleach in there now.
Its's very important these drain outside. (since it's basically distilled water it is GREat on plants, btw minus the bleach, of course.
Posted on Jul 14, 2010
The ice maker quit a few months ago (water still works) but I hear dripping into the drip pan.
sounds to me that ice tray fill tube is broken in the back as it runs up from the bottom to the tray , could that be the source of the sound of running water u hear ??? ill bet its intermittent , say 30 sec every two hours ??? and it stops making sound if u turn off ice maker ??
May 04, 2016 | KitchenAid Superba KSCS23IN Side by Side...
I have a Savio 2220 waterfall pump that is acting up. I have been running the waterfall for 3 years without a problem. Recently the pump will run a short time and trip the gfci. After letting it sit for a...
It sounds like a seal has broken and water is getting inside, tripping the GFCI. it may be possible to get a new set of gaskets for the pump, but it is not really an easy thing to do. Three years if it runs all day is quite a lot of hours. You could try a local electric motor shop, and ask for an estimate.
Jul 23, 2011 | Savio Water Master Solids Handling Pump...
My hampton bay air conditioner has started leaking badly after running it lfor a few hours, from the front right side
For window mount units, the unit must slope towards the outside. Water is a normal byproduct of refrigeration, like condensation on a glass of ice water.... Volume of water is not an issue, water dripping inside is. All water is intended to go outside, via unit slope.
Jun 28, 2011 | Hampton Bay Heating & Cooling
Water drip at base of freezer door at bottom!
Have you had a chance to locate the location the water inside freezer? There are many reasons for this to happen I just can not say it would be a defrost condensate drain blockage. Most times it is. Every 8 to 10 hours your freezer defrost and the water is surposed to follow a pipe or drain through the refrigerator to a pan below refrigerator where the warm air from condenser evaporates the water back to the air inside your home. That drain line sometimes slowly becomes blocked and then the drain hole becomes clogged with ice. Once that happens the drain needs to be cleared. I will try to help you solve this so for now I need you to see if water looks as if it came from rear of freezer. Placing photos on Flickr would be great! So tell me where you see it and yes we may need to pull a few things out. This is nothing a few towels, hair dryer hot water and Clorox and a wet vacuum cannot handle. Sea Breeze
Mar 20, 2010 | Maytag MSD2454G Side by Side Refrigerator
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
I have a unit in the attic and another part outside. I can stand inside under the ceiling vent and hear water running. When the unit cuts off, the water sound quits. I'm afraid something is not draining...
Sounds like your drain has sagged from the heat in the attic. It then backs up in the pan and sloshes around from the air moving. Get up there and see if that is the case, if so support the drain line so water runs freely to outside. This is an experienced guess. Good luck!
Aug 04, 2009 | Heating & Cooling
Fan loose , anti-freeze dripping
there is a weap hole in the bottom of the pump if it is leaking from that it is the pump they will make noise when they go out also
Apr 24, 2009 | 1999 Dodge Durango
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Car has a skunk like smell and AC question
Listen people...it isn't a skunk! My elantra smells like a skunk too and I am sure I didn't hit one. I think that it might be my battery; since battery acid and skunk smell are chemically the same. This is what I am checking next.
Aug 01, 2008 | 1997 Honda Accord
Maytag M3X05F2B Air Conditioner Logo
253 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
