Question about Kenwood KDC-MP7028 CD Player
Cant play cd in player it says (TOC) meaning the cd is dirty of no good so i put a new cd in and it still dident play.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
It's not your dirty CD but dirt on the head. Canned air usually works
But if not, very gently use alcohol and once over the optical laser then use the other end of the q tip to dry it.
I do this all the time just as a precaution. Unfortunately Netflix sends me a lot of dirty disks. quite a few cracked, too.
Posted on Jul 14, 2010
Older dvd player. put in movie and it sounds like
Hi, that is sounds like a dirty laser lens , try cleaned whit a q-tips whit alcool dont put to much pressure on the lens and try it to play a disk , if doesn't work and still searching the toc on the disk that means your laser pick up is out, you can see if the tirror belt is not skipping/ if not your dvd is out i mean the laser
hope that help,
have a nice day
Mar 26, 2010 | Televison & Video
My cd player in my car won't play cd's now. When
Hello there:
this means that it cant read the cd rom , because of the following conditions the cd rom is scratched or dirty or that the lens on the player is dirty and is in need of cleaning or that the player has failed all together
ok so try to clean the player with compressed air and a cd cleaner with some cleaner on it first than make sure that the cd rom is cleaned and not scratched and if still nothing is working you might want to consider a new player ok? Hope that this is very helpfull
best regards michael
Oct 23, 2009 | Panasonic CQ-DF903U CD Player
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
WHAT MEANS TOC ERR AND E-05?
TOC is Table of contents, sounds like you have a dirty CD or
the lens needs to be cleaned. Take it in to a professional to
have him clean it. Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
Toc error
toc error means "table of contents" error... means the player is unable to read the disc at all. May have a dirty focal lense to laser. clean gently with some windex on a cotton wool bud. It may be a faulty spindle motor that spins the disc. the bearings get worn or uneven and do not allow for disc reading to be successful. a check for this is a drop of oil to the bearing. It may then start to read discs, but will still require the motor to be replaced. . Check for the above... but if there is more required, take it to a Kenwood 'Agent... it may need a laser change
Dec 04, 2007 | Kenwood KDC-MP228 CD Player
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
Toc error
I have repaired many of these cd players working at an authorized Kenwood service center for over 17 years.
There are only 2 things you can do as the end user of this unit.
1. Try cleaning the disc's. If the cd has any fingerprints or scratches on the inner most part of the cd, the laser will not be able to read the TOC. It is the first thing the cd player tries to do and if that fails for any reason, the disc can not be played at all.
You can purchase a disc cleaning kit, or you can do what I do. I spray a small amount of windex on the data side of the disc and then clean it with a soft cloth like a bath towel or terry cloth. This works as good or better than the cleaning kits and is much cheaper.
If that does not work you can go to the next step.
2.. Clean the lens of the laser with a cd cleaning disc. They can be purchased at many stores that sell cd players and music cd's.
You put it in the player and let it run about 20 to 30 seconds and then you eject it.
If neither of these things help, you most likely have a bad laser pick up. You will need to take it to an authorized Kenwood service center and you can count on the repair being anywhere from $120 to $175. Depending on the rates and the mark-up of the laser pick up.
This is a very good car stereo, and is probably worth the repair cost, but it does have a 2 year warranty. It is not too old, so it may still be under warranty. If so, the repair is free for you.
I hope this helps you with this problem, and if so, a good rating is always appreciated.
Let me know if you have any other questions about it.
Oct 26, 2007 | Kenwood eXcelon KDC-X879 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Cd player wont play
The error code is a mechanical error fault, possibly something in the mechanics that load the CD onto the spindle motor. The only sure way to know what the problem is, is to open the unit and let it load a disc and see what happens. The problem may also be due to a very dirty laser lens, with a dirty lens the laser won't be able to read the TOC (table of contents) and all the CD's will cycle through the changer and a error code will be set. Best of Luck.
Sep 12, 2007 | Pioneer DEH-P6600 CD Player
Kenwood KDC-MP7028 CD Player Logo
56 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
