Question about De Dietrich DME112X Microwave Oven
Cleaning behind the front glass of De Dietrich microwave oven
My daughter has spilt a glass of milk on my De Dietrich microwave door. The milk streaks are behind the front glass and are very noticeable when the door is closed. Can this front glass be removed?
  • Possum_Phat Jul 14, 2010
    You mean like inbetween the front and the back?
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: De Dietrich DME 112 XU2 Turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Posted on Dec 15, 2008
Our De Dietrich DME715X microwave oven is sparking from the ceiling - have tried a new wave guide cover but that did not work.
Some ovens have a tuning stub in the wave guide. If it has become loose or rusted, it could cause the problem. If that's the cause, you would have to transfer all of the oven's components to a new cavity. This is usually not done due to the cost, although I did do this once on an oven that was still under warranty.
Make sure the wave guide is clean inside.
Also check for rust near the wave guide cover. Re painting damaged areas might help.
Sparks fly, too, if the ovens contents do not contain enough water to absorb enough of the microwave energy. Leftover energy converts itself into electrical current in any conductive material (such as cavity panels).
Nov 25, 2016 | De Dietrich Microwave Ovens
My De Dietrich DME 101XE1/3 microwave oven does not work.
I'd check the door switches first. The primary and secondary ones must go into the closed position when the door is shut.
You might also have an open thermal cut out on the outside of the cavity. There is also one on the magnetron you could check, although it's les likely to cause this problem.
Avoid all high voltage components, as there's likely to be a 4000 volt charge on the high voltage capacitor. Unpleasant to touch, and it could be fatal.
May 12, 2016 | De Dietrich Microwave Ovens
How to reset De Dietrich oven DO410
follow this step and fix it. A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
God bless you
Jul 20, 2013 | De Dietrich Microwave Ovens
Tried to change time on clock and all the power has gone out of the microwave
The fuse in the microwave has blown, there are any number of reasons for this, one of the door switches has failed, "common problem" or in some cases just the fuse will go.
Mar 25, 2012 | De Dietrich DME101 1000 Watts Convection /...
The turn table doesn't always rotate. If you move it manually it will sometimes work for a short while.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 04, 2011 | De Dietrich MM6768 900 Watts Convection /...
Sometimes heat food and then not
Basic
heatman101
Jan 11, 2011 | De Dietrich DME112X Microwave Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 19, 2008 | LG MV-1444Y Microwave Oven
Inside front of oven door is a water build-up
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 09, 2008 | Thermador MBBS Microwave Oven
Noisy turntable
I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
Mar 25, 2007 | De Dietrich DME112X Microwave Oven
De Dietrich DME112X Microwave Oven Logo
54 people viewed this question
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tom Chichester
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
