I have home theater with boston acquistic speakers and onkyo sr605 receiver. All speakers sounds good. but the center speaker is very low. even if i increased the volume of ccenter speaker its still low comparing to other speakers. how do I get loud sound from cetner speakers.
  • 4,924 Answers
This kinda systems have a integrated chip for each channel in part on the amplifier...and if the sound from it is trebled and low in volume it means that that part is gone for this channel and needs to be changed...to be sure this is what is about just switch the central with a left or right one to be sure that is not from the speaker itself..and for that you need to take it to an electrician to change it ...it is not an expensive part but the handwork may cost you a little ..
Posted on Jul 15, 2010
  • johan_kayati Jul 15, 2010
    you mean , should i connect center speaker with left /right one in the receiver?
    what exactly should i test?
  • Catalin Turcu
    Catalin Turcu Jul 15, 2010
    I said just to see if the speaker is not damaged..connect it in the place of another speaker...just change the jacks or the wires and see if it sounds normal .....if does...it means that it is not damaged..but the chanel for it in the amplifier is issued and the only thing that gets wrong and still make some noise is that amplifier chip ...if it do not work in another position on the exit...it means that the speaker is gone ...
When listening to network broadcast of nfl games and some movies the center speaker dialog seems faint
I've experienced the same thing on my TX-SR605. Some NFL games have too much of a surround mix, and it makes the center channel volume seem low. Also, some movies don't seem to be mixed well. Try the ProLogic 2x Movie setting. Also, you can manually adjust the center volume if necessary.
Sep 20, 2013 | Onkyo TX-NR616
Hoe to connect Bose Lifestyle 25 Home Theater System speakers to onkyo SRX-508
Do you mean TX-SR508? The following should work even if that is not the exact model.
The LS25 supports ONLY analog stereo audio input and the speakers themselves are NOT desigend to be driven by anything BUT the LS25 electronics.
If you still want to use the LS25 as speakers just run an RCA cable pair from VCR / DVR Out on the Onkyo to the AUX IN on the LS25 Music Center.
http://www.retrevo.com/support/Onkyo-TX-SR508-Receivers-manual/id/23653ag910/t/2/
http://www.retrevo.com/support/Bose-Lifestyle-25-Series-I-Home-Theater-Systems-manual/id/525ag019/t/2/
Dec 28, 2010 | Bose Lifestyle 25 System
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605. Low or no sound output
Does any good sound come through headphones, if you plug any in?
Apr 24, 2017 | Onkyo TX-SR605 Receiver
VERY LOW VOLUME FROM SORROUND SPEEKERs
some surround sounds do not put out loud sounds except from the front speakers only. Try using different inputs to see if it makes a difference.
Jun 17, 2009 | Onkyo TX-SR605 Receiver
Zone 2 Audio
help! screwed up z2 was working until i messed with it. do not know how to reactivate or even reset.
Apr 27, 2008 | Onkyo TX-SR605 Receiver
Audio problems - Onkyo TX-SR605
Same problem. Does the internal Cooling fan turn on?
Mar 21, 2008 | Onkyo TX-SR605 Receiver
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
Onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Dec 06, 2007 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
18 people viewed this question
 Grubhead
Grubhead
