Question about SATO GT408E Thermal Label Printer
I need printing commands to Print label using Visual basic
3 Suggested Answers
Sudrajat
  • 20 Answers
SOURCE: Printing
Have you tried using a SATO label Gallery? I think it's more compatible with SATO printer
Posted on Aug 25, 2007
  • 31 Answers
SOURCE: Ido not have any problem if I print label using
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Posted on Jan 31, 2010
Help to develop an application to print labels with SATO.
you must register with Benchfolks (http://e-learning.benchfolks.com/) an online e-learning center, they provide the best support for training courses and for placements.
Online IT Training Online IT Certification Training Placement
Apr 20, 2015 | Microsoft Visual Basic 6.0 for PC
Does ExtentNet 100x support Zebra printer language ZPL2?
It doesn't support it directly, but it shouldn't prevent it from working. However it might be sending extraneous PJL commands between print jobs (example @PJL -12345X) which could mess up a label. ZPL is basically ASCII, the ExtendNet shouldn't prevent ASCII delivery.
Feb 14, 2011 | Extended Systems ExtendNet 100X Print...
Printing labels from SAP ECC 6.0 using smarforms, label prints however the printer commands themselves are showing on the label, not just the information the print commands are to control. Is there...
Hi there
Does this printer connected with your computer? If yes, there is a problem on printer driver. You need to add new printer with same name and if this successfully installed, you can delete the old printer icon.
When there is errors message or wrong command of printing, the usual problem is corrupted driver.
Another way to correct this is to uninstall and reinstall the printer driver if the first solution does not work.
If still not working, try this download and install the print diagnostics software. It will helps you to find and fix errors in the windows registry. Here is the link http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Click on the blue text PRINT DIAGNOSTIC UTILITY and it will download automatically. Unzip it to install to your computer.
I hope these solutions solve your problem. Regards.
Feb 09, 2011 | Zebra RW 420 Thermal Printer
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Apr 06, 2009 | Datamax Prodigy Plus Thermal Printer
Programmatically printing using C#
You can print labels with windows driver or sending scape commands. If you have problems with the escapes you will design the label with bartender (you have a demo in the CD) and when you have finished with the design you can print to a file. Open that file and you will find all escape command needed to print.
Jan 23, 2009 | Toshiba B-SV4D Label Printer
Visual Basic 6.0 Code for Datamax ST3210
In www.datamaxcorp.com can find the programming manual of printers and you'll find examples of label design.
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Dec 05, 2007 | HP DeskJet 3940 InkJet Photo Printer
SATO GT408E Thermal Label Printer Logo
108 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
