Question about IBM Infoprint 1125 Laser Printer
How to obtain MAC address from IBM INfoprint 1125 printer?
5 Suggested Answers
SOURCE: infoprint 1412 on windows vista
I have the same problem with my 1412, if you find a driver please emial me.
Posted on Mar 19, 2008
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 21 Answers
SOURCE: Printer problem
could be hammer phasing
Posted on Sep 16, 2008
Wiired
  • 122 Answers
SOURCE: How to check the MAC address of Zebra 105SL Printer
go to the configuration on the printer. Scroll through until you reach the network settings. You can display or print the results, which will show the MAC address. Also, if you have a PC on the same network, and you know the IP of the printer, you can look at your ARP tables and find the MAC associated with the IP. ARP -a at the dos prompt
Posted on Jun 23, 2009
Reset factory settings on Infoprint 1312
To reset IBM Infoprint 1312 to factory settings, do following:
1. disconnect USB and network cables
2. switch power button to OFF
3. open toner door
4. press and hold both buttons (continue+cancel)
5. while holding buttons, switch power button to ON
6. keep holding buttons until printer initialization is finished (LED error is on)
7. close toner door
8. switch power button to OFF
Connecting printer in network:
Now you can connect printer with network cable, make sure DHCP works in your network. Switch power button to ON. Printer initialization should also obtain IP address from DHCP.
You can look in your router DHCP clients list or you can try to use software delivered with printer to find printer in network :)
When you go to IP of printer via browser, it will allow you to change some settings. Username to login is usually MarkNet, password is yours :)
This is all my personal exprience, it definitely works for this particular network printer :)
Mar 13, 2012 | IBM Infoprint 1312 Laser Printer
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
Pages are smudged and hard to read it looks like the cartridge is putting out too much toner
Smudging means that the "fuser" (which should be using heat to melt the toner into the paper) is not working, leaving the toner "loose" on the surface of the paper.
Take the printer to a qualified technician for repair.
Or, it might be cheaper to replace the printer!
Sep 27, 2010 | IBM Infoprint 1125 Laser Printer
I need to add IBM Infoprint 1116 to my home network using IP address. How can I change already setted IP and gatway addresses on it to needed?
If you know ip address of printer then you can access your printer with web interface for that type your printer ip address in internet explorer address bar.
then you can access configuration of printer.
But if you don't know ip then you need to check network configuration menu of printer .
For that press menu button of printer then enter in network settings then you can know the printer ip address.
Let me know if you need further assistance.
Thanks for using FixYa.
May 20, 2010 | IBM Infoprint 1116 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count
screen.
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
We have IBM Infoprint 1125 printer. The problem is that when You send a document from PC for printing it starts with printing and after a few seconds and several printed pages it starts to print very very...
Check the cassette, on certain printers if the cassette is set for the wrong size paper it will cause the printer to run slow, this happens on HP so it might be worth a try.
Oct 31, 2017 | IBM Infoprint 1125 Laser Printer
How to know the MAC address of my infoprint . In the config menu I got one but contains only 5 groups
If the printer is configured and has got a TCP/IP address, you can get the MAC mapping from any Windows PC in the same network like this:
Start -> Run Command -> enter "CMD" and press Enter -> type the command, PING ip.addr.of.printer (enter) and then ARP -a ip.addr.of.printer (enter).
If your network's IP addresses are centrally managed, ask your system administrator if it's possible to temporarily assign a fixed IP address for diagnostic purposes, then assign that address to the printer and do as described above.
Oct 30, 2009 | IBM Infoprint 1622 Laser Printer
IBM infoprinter operating manual
You should be able to find it in the support section of this page: http://www-07.ibm.com/printers/sg/products/workgrp_laser/info1125.html
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
Infoprint 1570 MFP (RICOH)
try accessing the machines web page( browser --address= ip address )
Jun 24, 2008 | IBM Infoprint 1570 Laser Printer
Invalid Engine Code After Paper Jam
remove the driver of the printer and reinstall...
Apr 01, 2008 | IBM Infoprint 1125 Laser Printer
IBM Infoprint 1125 Laser Printer Logo
104 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
