Question about Refrigerators
WHIRLPOOL GS6SHAXMB00 REFRIGERATOR THE UNIT HAS STOPPED COOLING AND FREEZING. FAN RUNS AND PERIODICALLY HEAR A RELAY AND COMPRESSOR TRYING TO COME ON. THANK YOU IN ADVANCE GUYS!!
    President:
  • 1,561 Answers
It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself.
Take care.
Posted on Jul 14, 2010
  • terry_keels Jul 14, 2010
    I NOTICED THE BOX ON THE LEFT SIDE WITH CIRCUIT BOARD INSIDE. WHAT IS THIS UNIT CALLED AND WHAT DOES IT DO? I MAY BE ABLE TO REPLACE THE COMPONENTS MYSELF BEFORE REPLACING IT.
  • Sulaimon Jimoh Olayemi Jul 14, 2010
    This is overload "klixon" to open protecting the
    compressor from fusing.
    Take care.
Gs6shaxmb00 repairs
See if you have power going to relay, and then take relay off then make sure each pin on compressor is not going to ground if so replace relay.
Jun 20, 2013 | Whirlpool Refrigerators
Whirlpool Wrn38rwg6 Freezer isn't freezing and I
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 16, 2011 | Whirlpool Refrigerators
My whirlpool frig model ed5ftg runs, lights on, fan running, seems like i hear a click, and don't cool or freeze
heatman101
Sep 08, 2011 | Refrigerators
Freeze and fridge not cooling the compressor is running and warm fans are working but not cooling whirlpool side by side
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
fsdtyr6t
Nov 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not freezing or cooling
The clicking is probably the starter/overload relay which starts the compressor. If the relay is good then the compressor is bad. Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Aug 30, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Gold Whirlpool 25.3 cu.ft refrigerator stop working
if the compressor is very hot then it can be possible that the compressor is getting faulty,but also other possibility can be the compressor relay.if the relay beside the compressor is got faulty then the compressor gets over heated.so first unplug the unit from main power outlet and then remove the relay and check it with continuity to confirm the fault.is it relay or compressor.
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
6 yr old whirlpool fridge/freezer side by side - no cooling
If the compressor is not running at all and not cooling or freezing it is most likely that the control module is u/s or that the compressor is u/s. If the compressor is running it ios most likely that the control module and / or the thermostat is u/s, or that the unit needs regassing. Call a service engineer.
Aug 16, 2009 | Refrigerators
NOT COOLING OR FREEZING
heatman101
k
Jul 16, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool side by side ED25DQXWN00 freezer stopped freezing
is the fan by compressor running? is the fan in the freezer running? is the compressor running or just trying and clicking periodically? if one of the fans isnt running..replace if compressor is clicking every so often..replace compressor start relay. lastly...is there frost in freezer on back wall towards bottom? defrost control/defrost t-stat/defrost heater.
Jun 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
