Question about Shure (PGX1485) Microphone
Transmitter of my mic does not satnsd at one channel
When i switch on my mic transmitter, it remains stable for 30 seconds and channels begin to change automatically. It is not stable anymore. any kind of help will be a great support for me.
With Regards
Vishal Goyal
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
It sounds like the button is probably sticking. I suggest sending it to Shure fore repairs. Info can be found at www.shure.com/service
Posted on Jul 19, 2010
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
My Shure mics work fine but two bodypacks are not working. Are there fixable parts in there?
Try switching mic's with known good system. The small diameter cable going to headset and lav mic's are easily damaged. If the mic feeding the bodypack is good, fresh battery, mute disengaged and channels set properly then it's Shure factory service time.
Feb 06, 2013 | Shure SLX1 Body-Pack Transmitter for...
Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Sep 07, 2012 | DIGITECH VOCALIST LIVE 2
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
NEED TO KNOW HOW TO RESET A PRESTIGE ELVATCE CAR ALARM
REPRIORITIZING A TRANSMITTER’S PROGRAMMING:
To reprogram a receiver channel with a different transmitter button once a code has been stored, there will be two options:
  1. Enter the transmitter program mode of the receiver channel to be reprogrammed. Using any unused button or combination of buttons, push out the stored code by pressing the unused button until a long chirp is heard, then repeat 3 additional times. After this, you can add any desired unused transmitter button. This action erases only that particular receiver channel, all other codes will remain stored.
  2. Enter the transmitter program mode. Using any transmitter button press and hold until a long chirp is heard. If a single chirp or multiple chirps, (up to 7 chirps), are heard, the unit is indicating that the transmitter has already been programmed elsewhere in the receiver. Release the transmitter button and within 5 seconds press and hold until a long chirp is heard. This action forces the unit to erase all stored codes of that transmitter.
The unit then exits the program mode the siren emits the program mode exit chirp pattern. All transmitter buttons for that transmitter must now be reprogrammed. Any other transmitter stored in the unit’s memory still remain operational. If the button is released and not pressed again within the 5 second period, no change in programming has been made to the receiver channel. The programmer can move onto a different channel or erase the transmitter codes as described in 1 above.
Regards, Martin @ http://www.lesscoelectronics.com
Sep 21, 2009 | APS20B Prestige Keyless Remote Alarm
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
Programing garagedoor opener
HOMELINKT UNIVERSAL
TRANSMITTER (IF EQUIPPED)
The HomeLinkt Universal
Transmitter, located underneath
the driver’s visor, provides a
convenient way to replace up to
three hand-held transmitters with
a single built-in device. This
feature will learn the radio
frequency codes of most current
transmitters to operate garage
doors and gates, and can also
control home or office lighting and
security systems (with the
available accessory package).
NEXT
MODE
Controls and features
42
When programming your
HomeLinkt Universal
Transmitter, you will be
operating the garage door or
gate. Be sure that people and
objects are out to the way to
prevent potential harm or
damage.
Do not use the HomeLinkt
Universal Transmitter with any
garage door opener that lacks
safety stop and reverse features as
required by U.S. federal safety
standards (this includes any garage
door opener model manufactured
before April 1, 1982). A garage
door which cannot detect an
object, signaling the door to stop
and reverse, does not meet current
U.S. federal safety standards. For
more information on this matter,
call toll-free: 1–800–355–3515.
Programming
1. Prepare for programming the
HomeLinkt Universal Transmitter
by erasing all three of the factory
default channels by holding down
the two outside controls until the
red light begins to flash (20-30
seconds). Release both controls.
2. Hold the end of your hand-held
transmitter against the HomeLinkt
Universal Transmitter (located on
your visor) while keeping the red
light in view.
43
3. Using both hands, press the
hand-held transmitter control and
the desired channel control on the
HomeLinkt Universal Transmitter.
Do not release the controls until
step 4 has been completed.
4. Hold down both controls until
the red light begins to flash slowly
and then rapidly. Rapid flashing
indicates successful programming
of the new frequency signal.
5. Follow steps 2 through 4 to
program the remaining two
channels.
If you do not successfully program
the HomeLinkt Universal
Transmitter after repeated
attempts, refer to Training a
rolling code
which follows or call
toll-free customer assistance:
1–800–355–3515.
44
Operating the HomeLinkT
Once programmed, the HomeLinkt
Universal Transmitter can be used
in place of hand-held transmitters.
To operate, simply press the
appropriate channel control on the
transmitter (the red light will
illuminate, indicating the signal is
being transmitted).
3. Press the programmed
HomeLinkt control in the vehicle
until the training light on the
garage door receiver turns solid
(1-2 seconds). Release the
HomeLinkt control and repress to
turn off the training light.
4. Press the HomeLinkt control
again. If the garage door activates,
Transmitter has been trained to
the receiver.
Erasing channels
To erase all three programmed
channels:
1. Hold down the two outside
controls until the red light begins
to flash.
2. Release both controls.
Channels cannot be erased
individually, but can be
reprogrammed. Refer to
Programming for instructions.
Oct 21, 2008 | 1999 Lincoln Town Car
Shure (PGX1485) Microphone Logo
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
