Question about Nokia N95 Cellular Phone
Everythink is working but nathing appears on the lcd screen
    President:
  • 1,561 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Posted on Jul 14, 2010
What is a tcon on lcd tvs
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 21, 2015 | Televison & Video
Turned it on and everythink has frozen. the screen sais philips and non of the buttons are working.
It may have only 'locked up;' pull the AC plug and ignore it overnight. This may not help but won't hurt anything and if it is a lockup, it may clear itself.
Mar 25, 2011 | Audio Players & Recorders
THE LCD IS BLAK
hi
if you mean you don't have any picture on LCD
you have to change the flat cable that connect LCD to main board
sometimes that cable disconnect because of shock so you have to connect it
Jul 28, 2010 | Panasonic Palmcorder PV-DV203 Mini DV...
When i plug camera to a computer nathing appears on the computer and i want to put phptos on the computer from camera. What shoudl i do
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
May 19, 2010 | Nikon Coolpix L11 Digital Camera
Cant get freeview
go to menu put it on dtv scan channels/if not its aerial
Apr 18, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hello i just installed my chimei 19" lcd to my hard drive and i have connected it all up right it all loads up but when my screen comes on the little button on screen goes from green to red and says no...
Most probably your monitor has two inputs, one digital and one analog. Using the monitor's on screen menu select the other input and you should see your picture.
Dec 18, 2009 | Acer AL1916W 19" LCD Monitor
Hey guys
  1. Enter the BIOS by pressing DEL button.
  2. Once BIOS screen is loaded scan the options and look for LOAD BEST DEFAULTS.
  3. Once default settings is loaded save changes by pressing F10. (Or try to find the save / quit option from menu )
  4. Just don't forget to save changes
Jun 17, 2008 | EPoX EP-4BEAV Motherboard
My Gateway Computer Screen is faded ,everythink looks like on the screen ...for example- you print something and no paint in the printer and the colors letters.etc. hardly visible ....so my computer screen...
It sounds like the voltages set in the LCD driver color references are dead. Maybe if you open it up it will have a loose voltage divider or bad LCD clock/voltage distribution boss circuit. It can of course be that the transistors on the panel are themselves destroyed, but check the below first:
Set the resolution to the monitor's native resolution (1680x1050), and change the panel's brightness and contrast to try and improve things. If it's not glare, make sure the temperature is okay for operating the monitor and perhaps check the video source (another video card or such.) Did the monitor always have this problem?
May 11, 2008 | Computers & Internet
Smudge marks???
If they are grease marks you can use a warm water a soft cloth like a t-shirt and little dish washing liquid. Gentley wipe the area only stroking down or up--- NEVER SIDE TO SIDE---. Have a dry cloth ready if you drip water down the screen. Now if those are scuff marks, your done, they cannot be removed. They are like the old record albums with the grooves, once the grooves get distorted that's it. Good luck.
May 07, 2008 | Toshiba 46H84 46" Rear Projection...
Nokia N95 Cellular Phone Logo
100 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
