Question about Whirlpool WFW8300SW
Where do i find the lint filter - Whirlpool WFW8300SW
    President:
  • 2,468 Answers
Theres a lint trap on the units pump located behind the access panel next to the floor just below the door,it just unscrews off the pump for clean out
Posted on Jul 14, 2010
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
I have lots of lint that gets trapped under and all around lint filter and it is very hard to get out - why is it not being contained? GE Dryer DBVH512EFOWW front load.
Hi rstebly...
Sometimes the problem is with the lint filter itself...
If you use "dryer sheets" they can plug up the holes in the lint filter with a kind of waxy substance and that will impair the air getting thru the filter causing the lint and air to find another way out, not thru the filter but thru the machine.
I would suggest you take the filter out and wash/scrub, lightly it in hot soapy water, let dry, then reinstall the filter.
You should also check the blower /blower tube and the inside of your dryer for lint buildup also, as lint buildup can cause dryer fires.
Hopefully this will solve your problem
Free Answer...Please rate me
Apr 28, 2011 | GE DBVH512EFWW Dryer
Dryer "clean lint filter" message
Hello. Begin by unplugging the plug on the dryer. Then pull out the filter and thoroughly examine the space that the filter slides into looking for any lint. Remove any lint that you find. Put the filter back and lastly plug the dryer back in.
These steps should solve the problem. If not, then the lint sensor has gone bad and should be replaced. If you wish to do that yourself you can go to searspartsdirect.com. Enter the model number of the dryer and then you will see the parts diagrams allowing you to locate that lint sensor, and even order a new one. Joe
Thanks for choosing Fixya!
Mar 07, 2011 | Dryers
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
I need a part number for the lint screen fora 9200l series dryer i lost the manual please help
Hello there:
Whirlpool recommends
8557884 Whirlpool Kenmore Lint Filter (screen)
This Genuine Whirlpool dryer lint filter is used on Whirlpool, Kenmore, KitchenAid and Roper dryers.
Special Note ***** Does your filter have a black spacer below the handle?.
************ If so you may need the Whirlpool Dryer Filter 8557857
The 8557884 Whirlpool Kenmore Lint Filter (lint catcher) is about 17 and 1/2 inches long and has a white handle
Hope this is helpful for you
best regards Michael
Nov 30, 2009 | Whirlpool GEW9200L Electric Dryer
Looking for the lint filter
you did not give me a mod # of your washer .... so i will go through the history of the lint filter 1955-1964 the lint filter was on the right side under the lid , twist knob and pull screen out 1965-1986 lint filter was self cleaning mounted under the washer 1987 -today there is no lint filters any more ..... lint filters where used when people hung the clothes out on the line .... today most people use a DRYER that has the lint filter in it .... i hope this helpes ....... if you are going to rate this please rate this 3 or 4 stars , that will keep me in the paid answer department . thanks
Apr 01, 2009 | Washing Machines
Lint filter not blocking lint
Make sure it isn't bent or has any holes in it and is sealing around the edges. If not, replace it .
Mar 19, 2009 | GE DCVH515EFWW Electric Dryer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Whirlpool WFW8300SW Logo
81 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
