Question about HP LaserJet M1522n MultiFunction Printer
49 error turn power off then on - HP LaserJet M1522n MultiFunction Printer
    Champion:
  • HP Expert
  • 202 Answers
This is the firmwere error pls turn off the printer up to 30 min then on if problem persiste replace the formatter cart ur problem will be resolved
Posted on Jul 14, 2010
  • l_croft_2001
    l_croft_2001 Jul 04, 2012
    Where do you get the reformatter card?
Good day, i have a problem with my printer laserjet 1522nf. the problem is that 49 service error. I already replaced the formatter and the modem but still the same problem. can u help me for that?
Posted on May 02, 2011
  • jitendra mishra
    jitendra mishra Jan 06, 2013
    in 1522nf printer it comes from formatter card & adf scanner piz cross check both
Error 49.38.07
Power off the printer for a minute. Power it on. Do you get the 49 error, does the printer READY? If it comes READY wait a few minutes. No 49 error? start printing, anything. 49 come back? clear the print queue after powering off the printer. Power back on. Do what you did above. No 49 error, it was probably a bad print job in the queue. If it comes back again, you will have to go to www.hp.com/support and answer the questions until you get to the FIRMWARE UPGRADE. Read it carefully and do it.
It's also possible there is a bad network, bad memory or bad formatter.
Jul 08, 2014 | HP Laserjet P3015X Printer
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
No display clean ram and switch on ok but not reddy 49.FF05 ERROR in valied nand key press any key
ISSUE: A 49.x service error appears on the HP Color LaserJet 4500 or 4550 printers display, and other unexpected errors may be displayed such as:
  1. Turn the printer off, and then turn it on again. If the 49 error clears, proceed to Step 9.
  2. If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card, which is located on the formatter, (see Figure 1 for location), or any third-party devices, if installed.
  3. Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
  4. Turn the printer on, using a cold reset. If the 49 error returns, turn the power off, and unplug the printer. Remove the formatter, and check that the parallel I/O board is firmly installed on the formatter board.
    NOTE: To perform a cold reset, turn the printer off, and hold down the GO button while turning the printer back on. Remember to remove the Jetdirect card (if installed) before performing a cold reset. (The Jetdirect card is located on the formatter).
Mar 28, 2013 | HP LaserJet Office Equipment & Supplies
49 error turn off then on
49 Error, Turn off then on
The product has experienced an internal embedded software error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If the error persists, see that link
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3442750&prodTypeId=18972&prodSeriesId=3442750&objectID=c01558499
Aug 07, 2011 | HP LaserJet M1522nf Multifunction Printer...
Error 49 is showing in the Printer Screen, it is automatically getting switched on and off in close intervals and not functioning. Printer Model is HP LaserJet M1522nf.
If the error persists, contact HP. See
www.hp.com/support/ljm1522 or the support
flyer that came in the product box.
Jul 11, 2011 | HP LaserJet M1522n MultiFunction Printer
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on. Change the network cable but no use
Had the same error. Turned out the pdf I wanted to print had an empty page. When I removed it, the error disappeared and I could print the document.
Mar 13, 2011 | HP P2055DN LaserJet Monochrome Printer
Stampante nf 1522 errore 49 non invia e non riceve fax grazie
49 error is an internal embedded software error.
1) turn off power and wait about 30 seconds, power on and if error comes back, see step 2
2) www.hp.com/support/ljm1522
Jan 14, 2011 | HP LaserJet M1522nf Multifunction Printer...
When the printer is booting it is stuck at **************************, when it do comes on it comes with error code Error 49.4c02 Product model: HP Laserjet 4100N
Thank you for contacting FixYa with your printer inquiry.
HP Laser Jet 4100 49.4C02 Error
49.xxxx PRINTER ERROR
Description 49 errors are generally communication errors or file related issues and can usually be resolved by following the steps below:
Action Turn the printer off, and then turn it on again.
If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card (or any third-party devices), if installed.
Turn the printer on. If the 49 error returns, turn the power off, and then unplug the printer. Remove the formatter board.
Check that the parallel I/O board is firmly installed on the formatter board.
Check for any non-HP memory DIMMs. If any extra memory is installed, remove it.
Reconnect the power cord, and turn the power on.
If the 49 error returns, perform a cold reset.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence. If the error code continues to come back, it requires a firmware upgrade.
If the 49 error returns, contact an HP-authorized service or support provider.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 05, 2011 | HP LaserJet 4350 Printer
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
Error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Recommended action 49 and 79 Errors, Turn off then on The product has experienced an internal embedded software error. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Jul 02, 2009 | HP Laserjet M2727nf Multifunction Printer
HP LaserJet M1522n MultiFunction Printer Logo
706 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
