Question about Intel PRO/Wireless 2200BG 802.11g/b
I have a hp 510 laptop that won't connect to the wireless router. It gives this error "windows is unable to connect to the selected network. The network may no longer be in range" but other laptops around connect to the same linksys router. thanks
    Scholar:
  • 103 Answers
Have you try to check the IP ADDRESS of your laptop? Your laptop must have a unique IP address or it must have the same default gateway with your ISP provider or the router. see example below,
IP ADDRESS: 192.168.1.15
SUBNET MASK: 255.255.255.0
DEFAULT GATEWAY: 192.168.1.1
preffered DNS server: 192.168.1.1
note: 192.168.1.1 is the IP ADDRESS of your internet or ROUTER that is given from your ISP that they've configured.
try to check the other laptops that was able to connect, you can follow it.
Posted on Jul 14, 2010
I have IBM Thinkpad R52 & Compaq Presario V2000 Notebook pc. Iam using windows xp on both but whenever i trying to connect wireless network its showing "windows unable to connect the selected...
To connect to your wireless router, the router's wireless settings needs to be configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 03, 2011 | Computers & Internet
Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
Jun 03, 2010 | Intel Computers & Internet
My HP laptop won't connect to my NETGEAR WGR614v7 router
What is your operating system (Vista/XP, older Windows)? Have you turned on the router's wireless router radio from the computer that is connecting? (Login to the router's setup page at 192.168.1.1 or 192.168.0.1 (depending on the router) and go to Advanced menu and click Wireless Settings.) While you are there, enable the SSID Broadcast (another checkbox hust below the one for Wireless Router Radio). Now check if your laptop can see the router.
Additional FAQs that might be helpful are at http://kb.netgear.com/app/products/model/a_id/2589. That page has a link to setting up XP for wireless networking as well.
Aug 11, 2009 | NetGear WGR614 Wireless Router
Wireless connection
check to make sure the wireless zero configuration utility is on ..check from services in the computer and make sure that there is a check in use windows on the network card itself from network connections. Then it should work .
Jun 13, 2009 | Actiontec GT704WG Wireless Router...
''unable to connect to selected network'' error
If you can connect your laptop to other wireless and others can connect to your wireless but you cannot means that its on your laptop wireless network configuration.
If you have Windows XP, go to Start > Connect to > right click on your wireless connection and select "Properties". Choose the "Wireless Network" tab and under "Preferred networks" remove ALL wireless network, reboot your PC and then go here again and then re-Add your own wireless network only. After you Add highlight it and click "properties" button. Checked "Connect even if this network is not broadcasting and if you have put a security on your wireless to select the correct authentication type.
Then on "Connection" tab checked "Connect when this network is in range". On "Advanced" tab make sure to Uncheck "Automatically connect to non-preferred networks".
On Windows Vista delete all Preferred Networks under "Manage Wireless Networks",(under Network and Sharing Center on Control Panel). then turn off and on your pc. And then try to reconnect and make sure this time, PC will ask for network key. ( if you set it up that way )
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
"unable to connect to selected network" error
Hi, May be your router is now running a more secure algorith and needs password etc which the old one can't handle. You may have to downgrade your router to the older system..not a good idea.
CAN'T CONNECT TO WIRELESS ROUTER WITH LAPTOP.
Temporarily disable all security on the router AND your laptop wireless card and try again to test connectivity.
The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it should30924e8.jpg work.
Also check to make sure that IEEE 802.1x authentication on the wireless network properties Authentication tab is disabled.
Jan 04, 2009 | Linksys WRT160N Wireless Router
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Intel PRO/Wireless 2200BG 802.11g/b Logo
497 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
