Question about GE Spectra JBP78 Electric Kitchen Range
Have a ge JBP72TOK1WW all burner work but oven and all timer not
SOURCE: GE Spectra Oven not working
What is "the board"? and is this replaceable by a fairly competent user or does this require a service call? Thanks!
Posted on Feb 07, 2007
  • 338 Answers
SOURCE: Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Posted on Nov 30, 2008
  • 22 Answers
SOURCE: After oven cleaning,
GE to8 (oven) control. Part replacement.
Posted on Mar 15, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Posted on Feb 04, 2010
fixyourboard
  • 310 Answers
SOURCE: I have a GE XL44
This is a failure with the clock module. You can replace it with a new one, or fixyourboard.com rebuild it to save you some cost.
Posted on Aug 14, 2010
Testimonial: "Great feedback, now I know part to get. Thanks"
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
My oven does not heat up. Everything else on the stove works (top burners, clock, timer, ect.) When you turn the oven dial, it even clicks as if it were to start the oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 10, 2011 | GE JGRP17 Gas Single Oven
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
I have a GE Model JGBP265BEA1WH and the oven would not work. The broiler & stove top did. I replaced the ignitor and now both the oven and broiler do not work but the burners do. I tried to locate the...
The burners and its components are totally seperate from oven and there is no controlling shared between them. The problem can be many. Can be the timer control that is locked and not allowing any oven functions. Can be the electricline feeding the oven portion. Can be the oven temp control that tells bake and broil to begin functioning. Can be oven lockout. This is a function that you can turn off by holding the clock or other pad button for 3 seconds. Check your manual to see if I am correct about which touch pad to hold. This is a safety feature that sometimes gets activated and there's no flashing lights telling you about it. Goodluck<Macgivor
Jan 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
I have a 1950'S GE range and can't locate the Model number This range has 4 burners, the oven has chrome on the inside of the oven door. there are slide out compartments under the oven and on the left side...
I believe the model number is inside the drawer to the left of the oven near the top on a metal plate. it wont say model number as it was a catalog number. it will say cat. no
Nov 07, 2009 | GE Kitchen Ranges
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Mar 15, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven not working
check its fuses, might be one of them has blown/ open.
Jul 30, 2008 | GE JBP71 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
87 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
