Question about Bosch 24 in. SHX46B05 Stainless Steel Built-in Dishwasher
Bosch dishwasher, low water pressure, arms not turning
I got a bosch sgs45e02gb/45 dishwasher. All was OK until yesterday, when everything remained dirty. Have done a bit of digging and wondered if anyone can help me out, cheers.
The water doesn't come through with enough pressure to turn the rotary arms. I stuck a screwdriver in the door sensor and managed to start it on a cycle with the door open to see what was going on. When the water is coming through the top arm it doesn't move, after about a minute it then changes to the bottom arm, after about a 20-30 seconds there is enough pressure to turn the arm but it takes about 20 seconds for a full turn. If I turn it off and back on again the cycle starts from the opposite arm to which it was when I turned it off but this time it turns with full pressure for a full half turn before previous symptoms return. It drains as it should.
silly girl
  • 513 Answers
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Posted on Mar 26, 2006
  • 236 Answers
SOURCE: Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Posted on Jun 16, 2007
  • 27 Answers
SOURCE: Bosch Dishwasher odor
Make sure that drain hose is not kinked, and that the unit is draining properly. Odours are most commonly caused by the unit not draining properly and subsequently using the dirty water in the rinse cycles as well....not perfect washing results will be the tell-tale sign here....
Posted on Jun 26, 2007
SOURCE: Bosch Dishwasher SHU53152
In some models one can select either the top rotor or bottom. being a new unit possibly you have not seen options given. very seldom a timer related problem.
Posted on Jun 09, 2008
  • 7 Answers
SOURCE: Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Posted on Jul 23, 2008
Bosch Dishwasher SMS40A08GB Silver Edition. Check Water light comes on but no error codes.
The unit may have developed a leak underneath and it may have a bad heater element. Pull the unit forward and put towels behind it on the floor, tilt it back 45 degrees to drain the water, wipe up the excess and put it back in position. Test it.
Apr 30, 2018 | Bosch Dishwashers
Hii My dishwasher is working well until yesterday , I think the water pressure is not working well , it is Bosch silenceplus any help please
Turn off the water and remove the inlet hoses. There is a small stainless steel gauze filter that can get clogged with particles.
If that doesn't fix it, you may need a new water inlet valve.
Feb 19, 2018 | Bosch Dishwashers
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
My Bosch SHX56BO6UC14 is not getting the dishes clean at all. It's making a grinding sound. It is pumping water & spraying water, but not getting anything clean. help?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 09, 2011 | Bosch Dishwashers
Dishes Don't clean
If the machine motor runs and the cycles all seem to be working.Check if the rotating arms are spinning when the machine is turned on.
If it isn't then the water pressure is too low and not spining the arms. You have a pump problem, likely the impeller is broken. I had the same issue with mine
Apr 26, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Sep 18, 2009 | Bosch 24 in. SHX46B05 Stainless Steel...
Bosch Dishwasher will not take in water
Either the pressure is too low, or turned off by accident. Otherwise it could be a faulty inlet valve
Please leave feedback
Thanks
Rob
Feb 13, 2009 | Bosch (1619EVS-RT)
Bosch shu3036 upper arm with low pressure
check water level should just appear above filter failing that a common fault on these is the impellor wings have worn you need to strip wash motor down to get impellor cover off
Jan 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
See all Bosch 24 in. SHX46B05 Stainless Steel Built-in Questions
Bosch 24 in. SHX46B05 Stainless Steel Built-in Dishwasher Logo
905 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
