Question about 2wire (1000-000057-000) Modem
If i disconect the ethernet cable from my laptop my wireless doesnt work at all
    Scholar:
  • 103 Answers
Maybe your laptop is configured to be the Internet server that is why every time you disconnect the Ethernet cable you lost connection. Your laptop is the one that gives connection to other computers.
Posted on Jul 16, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
My router is situated in my bedroom and can only get on to inter-net when have ethernet cable connected to my router and laptop, when i disconect ethernet cable and take laptop to another room it will not...
Thank you for using FixYa
In order to use the laptop in another room, your router must be a wireless router. If it is a wireless router you will need to Create a new wireless connection on your laptop in order to connect to it. Go into your control panel or system and use the Wizard to create a new connection. Since I do not know what operating system or hardware you are using this is not a specific answer but I am giving you the general procedure that you will have to follow.
I hope this was useful and please comment if this was helpful to you.
Jun 29, 2011 | Belkin Computers & Internet
My pc will not connect to my broadband but my laptops do. all are wireless? what could the problem be and how can i fix it? thanks
Could be the wireless card in your pc or your network card. Check the pc with an ethernet cable plugged if it works online your wireless card or settings or the problem. If it doesnt work wired contact your pc vendor.
Apr 14, 2010 | Computers & Internet
I set up my laptop using a Belkin wireless router, and it is o.k. thro ethernet by does not recognise wireless when I disconnect the ethernet cable!!
Well the best shot is to reset the router back to factory by pressing the reset button for 10 seconds then it will flash a couple of times. then see if your laptop can connect to the router, If that doesnt work let me know
Nov 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless network disconects when connecting xbox 360
Are you connected to the router wired, or wireless?
Have you set your laptop to a static IP on you network, and your X-box is set to the same?
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Dell inspiron 1525
check your lan card maybe it is disable, try to enable it
Apr 12, 2008 | Dell Inspiron 6400 Notebook
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Wireless router
OK classychick,
do you have a wireless card in you PC/ laptop? If you have you should set this to the same settings on your router.
eg. SSID = {whatever you want}
WEP encryption 64 bit = {10 chars from a-f and 0-9}
or WPA encryption = {a word}
Has the wireless on the PC/Laptop been turned on?
Cheers
Tim
Dec 13, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
2wire (1000-000057-000) Modem Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
