Question about Dometic Rooftop RV Air Conditioner
Wiring I am replacing a standard Dometic thermstat with a multi-functional therostat ia a Moaco. I can't eem to find a wiring diagram and it s difficult as Dometic uses a ribbon plug. I just need the color of "Power", "Compressor Trigger", and "Fan". The new thermostat has "Fan Speed" if the Dometic unit is compatable, "Fan Speed" triggers would be helpful as well. Thanks in advance, Ron at Viking Marine Services
  • Ron Dvorak Jul 14, 2010
    I have the wiring for the thermostat, it came with it. The connector from the AC unit, on the roof, is a ribbon and I can tell one wire from another. I need the color codes for the AC unit.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
Maybe try calling Grainger or they might have a website online. Have you googled the brand of your thermostat? Often PDFs pop up with manuals.
Posted on Jul 14, 2010
I need a wiring diagram for a dometic ndr 1092 eyebrow. specifically the humidity and frost switch
call 888-782-6665 they say they will help with their products and answer questions
Jul 25, 2016 | Dometic Refrigerators
Need wiring diagram for montana 2955rl wiring in dometic ac
you can go on line for trouble shooting your dometic unit. it will give you all the info including wiring.
Sep 13, 2015 | Dometic Heating & Cooling
Thermostat wiring diagram for Domestic RV rooftop AC
go on internet look up troubleshooting dometic rv a/c's
Feb 13, 2015 | Dometic Rooftop RV Air Conditioner
Honeywell wiring diagrams
WE R GOING FROM A HONEYWELL TAYSTAT500 THERMSTAT (HEAT PUMP) TO A NEW HONEYWELL to (WHOLE NEWHEATING/AIR CONDITIONER) WITH A HONEYWELL RTH8580WF1007 THERMOSTAT? WHERE WOULD THE C WIRE BE. WE DO NOT HAVE A WIRING SCHEMATIC FOR THE OLF THERMOSTAT. IT HAS 7 WIRES. HELP?
Jan 10, 2014 | Heating & Cooling
Need a wiring diagram for a 1998 ford explorer headlight switch
The DK BLU/ORG wire from fuse 12 connects to terminal 6. The RED/YEL wire from the multi-function switch connects to terminal 2. A second DK BLU/ORG wire from fuse 12 connects to the multi-function switch and has nothing to do with the headlight switch
Oct 26, 2012 | 1998 Ford Explorer
Ford taurus hazard lights and turn signals not working
remove bottom screws under the steering wheel remove bottom cover and then the top cover where the turn signal arm sticks out . then remove the connector attached to the multi function switch at the turn signal arm. spray real good with circit cleaner . then put connector back on. should then ,if not replace the turn signal arm which has the multi function switch attached .about 50 dollars on a 96 taurus at auto zone.
Apr 13, 2012 | 2002 Ford Taurus
Cruise control stopped working in our 1998 ford explorer can't find the problem and can't find a diagram of system to be able to check it.
Chances are that you will need to replace the Multi-Function switch. There is a common problem for Explorers to have the switch fail. A multi-function switch controls the cruise, wipers, blinkers and if even one item is not working then will still need to be replaced. Usually you can find a wiring diagram on Mitchell on Demand Do - It yourself website.
Jan 17, 2010 | 1997 Ford Explorer AWD
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
275 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
