I have a 300 litre rheem water cylinder and for the first time ever we have no hot water model is a 312.300.15
  • 408 Answers
SOURCE: Rheem Hot Water Cylider Thermostat keeps tripping
Sounds like you have a faulty thermostat.  This is the unit that detects the water temperature, and if it is not where it is set, will kick the switch to allow electricity to flow to the elements you replaced. The thermostats are relatively cheap and if you have the knowledge to change the elements, changing these thermostats should not be a problem.
Posted on Mar 07, 2009
  • 234 Answers
SOURCE: I have a probally ancient hotwater heater rheem
You will find two covers on the front.Behind each cover the you will find a thermostat ,there will be adail on it. It might be numbers like 120,150 or it might be letters,like A,B,C and so on.You take screw driver and turn to the right until you get the tempture you want.
Posted on Mar 23, 2009
  • 7 Answers
SOURCE: My Rheem hot water heater stopped putting out hot
If you are not familiar with the element, I would get someone that is familiar with one and have them do it. It's not something I would recommend you do based on your question. There's electrical, pressurized water tank, and a whole lot of water that may cause you to have a worse bad day.
Posted on Jun 26, 2009
muttandjeff
  • 359 Answers
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Posted on Jan 05, 2010
  • 6 Answers
SOURCE: Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Posted on Feb 03, 2010
Water heater leaking
I would call home depot and ask how they handle their warranty with Rheem. Contact your builder and get the information of the plumier that installed the unit he should be able to give you the pluming supplier where he purchased the heater.
Jan 20, 2014 | Rheem Water Heaters
We have a 15 year old Rheem "SK 1261" which recently has developed a steady and constant hot water drip from the hot water over flow. Initially it was a slow and inconsisent drip but now it...
If you are paying for your water, I litre per hour is going to cost you. If the unit is 15 years old, I would seroiusly comsider replacing it buy, if it's just a bad valve, you could try to replace it. If it is cracked at the threads, it's time to replace it for sure.
Dave
Jun 24, 2011 | Rheem Water Heaters
I have a 135 litre, 10 year old Rheen mains pressu...
usually on the hot water piping, It starts to rust closed faster than the cold side, due to electrolosis. What you r discribing are the first signs of this happening. only solution is to replace the effected pipes..
May 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem model #GP40T6PF00 lp hot water heater Will
sounds like one of the saftey relays might be going bad. or the ingniter might be cracked or need cleaning
Mar 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to drain the rheem 135 litre tank
1. turn off the electrical power first.
2. attach a garden hose to the hose bib attachement on the bottom of the water tank and run the hose outside to allow the water to drain out by gravity.
3. Turn the valve that is on the inlet of the water heater. Now that the power is off, you can drain the tank.
4. open the drain valve where the hose has been attached.
5. To release the pressure, you can open a hot water faucet in your kitchen. This will allow the water to drain out easier.
Sep 12, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have a rheem gas water heater for manufactured homes...model 211R40DV....all of a sudden the pilot goes out occasional and the water is very hot, even on low setting...a repair man told me only place to...
First off, the repair man is right that it is the thermostat.I'm guessing his quote was the cost of part and labor to install it. You can buy a new one for around $300. to $350. ish.
Hope this helps.
Aug 14, 2009 | Rheem Water Heaters
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
