Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
I can't figure out how to record message for answering machine
I have tried everything on the scroll down BUT can't find how to record message for answering machine
HELP
    Genius:
  • 1,340 Answers
There should be a greeting or greet labeled button on the base.Hold it down and it will prompt you.If there isn't one,without turning on the phone hit the funtion button.There should be a directional button to cycle you through the options.It should be on the base though.We just got rid of our Uniden though because the batteries died and there are so many new ones that come out year to year,they don't even put out the battery anymore.It is less than 2 years old too.:( Good luck!
Posted on Jul 23, 2010
Why my uniden dect 6.0 answering phone has announce only and not record message
Check settings. Go to menu / sel button, press once. Scroll down to answering setup. Select. Scroll to record time. Options are announce only, 1 min. Or 4 min. Make selection. You will know your machine is ready to answer and record messages by the change in the LCD display on phone base from "A" (announce only) to a number, designating the number of messages previously saved.
May 11, 2012 | Uniden DECT 6.0 Cordless Telephone...
I have a gigaset 4215 answering machine (but it says 4200 on the actual phone)...but no manual...and am trying to figure out how to record message for the answering machine so people know its mine...but...
You control the answering machine from the handset. First turn on the answering machine. Press Menu then use the up/down arrows keys to navigate to Ans Machine. Press OK then navigate to Answering M. Look for a check next to this to indicate it is on. Press OK to toggle the answering system on or off. Then press End or left arrow to return to the previous menu. If the machine's memory is full, it will switch off. Delete messages so that the unit will keep the answering machine feature on.
Next to record a new message follow the above steps to reach the Ans Machine menu and press OK. Scroll to Announcements and press OK. Scroll to Record Annc or Rec Annc Only (if no messages will be recorded). Press OK then bring the handset to your ear and listen for the notification of recording and then the tone. State your message clearly into the microphone of the handset. Press End to stop recording and listen to the unit play back your announcement. (It will stop automatically after 170 seconds or a 2 second pause in your speaking.) If an Annc Only message is available, the machine will play it when the memory is full. Otherwise, it will turn off.
To select your announcement (and recording type) follow the above steps to Announcements and press OK. Then scroll to Mode and press OK. Scroll to Annc or Annc Only (available if the Announcement only recording has been made) then press OK. Again OK toggles the announcement on or off; look for a check mark to indicate the announcement will be played. Press End to exit the menu.
Retrevo has the manual for the Gigaset 4215 here: http://www.retrevo.com/support/Siemens-4215-Telephones-manual/id/23319bh144/t/2/ . You will need to enter a code to download the file.
I hope this helps.
May 05, 2011 | Siemens Gigaset 4215 Cordless Phone
I have lost my instruction book for a Philips cordless phone model number SE 455 DUO and need to change my message. how do I do this
Try the online manual - http://www.p4c.philips.com/files/s/se4552b_17/se4552b_17_dfu_aen.pdf
Go to MENU , scroll to and select Answer Machine, scroll to and select Record OGM (OutGoingMessage) and select one of the two options.
May 17, 2010 | Philips Lands Phones
How to I record a message for answering machine
Press "MENU"
Scroll to "Answering Machine", Press "Set/Save"
Scroll to "Record Greeting", Press "Set/Save"
Following Instructions that appear on LCD screen to record message.
Jan 30, 2009 | RCA 25425RE1 Phone
Panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Jan 10, 2009 | Panasonic KX-TG2740 Cordless Phone
Static in the recorded message. AT&T model 1738
The microphone (located inside the unit and faces downward towards the surface below the answering machine) might be defective. One option would be to call into the answering machine and try recording your message that way.
Other than that, there really isn't much you can do for this problem other than replace the unit.
Dec 15, 2008 | AT&T 1738 Digital Answering Machine
How do I change the recorded message?`
Record Your Announcement
Before using this answering system, you
should record the announcement (up to
three minutes long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a pre-recorded
announcement: “HELLO. PLEASE LEAVE A
MESSAGE AFTER THE TONE.”
1 Press and hold a. When the
system beeps, speak toward the
microphone normally, from about nine
inches away. While you are recording,
the Message Window blinks .
2 To stop recording, release a.
The system automatically plays back
your announcement.
To review your announcement, press
and release a.
To erase your announcement and
return to the pre-recorded announcement,
press Dwhile your announcement is
playing.
Callers can skip the announcement by
pressing #.
HAPPY TRAILS!!
Apr 17, 2008 | AT&T 1738 Digital Answering Machine
BINATONE CORDLESS PHONE MA 760
you have to press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button scroll to OGM REC. record ya message after the tone then press ok when done. then scroll down the menus again (press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button) scroll to TAM ON, press ok and thats the answering machine.
Mar 21, 2008 | Lands Phones
Change Answering Machine message in Lucent 1872 corded phone
Try just pressing down on the greeting button on the answering machine, you will hear the lady say "record greeting" and keep holdong down until you are finished recording the message. When you are done, remove your finger, done!
Nov 19, 2007 | Lands Phones
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
89 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
