Question about Ariens Zeroturn 2660 Hd 60" Riding Mower
Replaced solenoid on ariens 0 turn lawn mower.jerks & jumps now.
Replaced solenoid because it wouldn't start. Solenoid replaced and now when running it jumps, jerks so much gasoline sloshs out around cap. Could installation have caused this or was it reassembled wrong after installation?
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 246 Answers
SOURCE: ariens lawn mower 1332 dies when put in gear
Hello
From your Description it Sounds like a Bad Saet Safety Switch.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
  • 53 Answers
SOURCE: Sears lawn tractor 917256491 unable to activate start solenoid.
first see if u can jump the started with a screw driver, also check fuse could be blown. do u have battery voltage? here is a site for a wiring diagram www.managemyhome.com.
Posted on Jul 23, 2009
  • 74 Answers
SOURCE: need a wire diagram to reconnect starter solenoid
http://i107.photobucket.com/albums/m314/Restrorob/MTD/MTDOHVTwinWireDiagram.jpg
Posted on Sep 20, 2009
Mower will not start by key. I can jump across silinoid and mower will start right up no problem.Why is it not starting by the key?
H Albert:
If it starts when you jump across the solenoid, but not when you jump from the positive to the exciter terminal on the solenoid, then the solenoid needs to be replaced.
If it does not start from the exciter terminal short, then power is not getting from the switch to the exciter. Check wiring and switch functions.
Cheers
May 06, 2016 | Garden
Who makes arien mowers
this is a common silenoid used by many mower companys
Jul 08, 2014 | Ariens Lawn Mower Universal Solenoid...
2009 zt bad boy wont start unless you jump solenoid which is new starter is rebuilt relay replaced . Ignition switch new replaced . wont turn on with key - jump solenoid fires up runs then pops the 25...
if you are blowing fuses then you have something shorted out or connected wrong. before you spend more money throwing parts at it get a wiring diagram and ensure the wires are good and connected right
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 28, 2013 | Garden
Replace starter
your solenoid is marked for its connections and the instructions that came with the solenoid should tell you what you need
Sep 12, 2013 | Ariens Lawn Mower Universal Solenoid...
Rider 155 wont start unless you cross starter solenoid
On my Ariens, had the same issue, where, with a new battery, mower would not start, unless I jumped across the solenoid. Figured the switch was fine, because it would only start if turned on, and would power off when I turned it off. Had no idea there was a 20amp fuse in the mix. Thanks to Tim Whalen for his response from years ago. Replaced the fuse, dangling in a harness near the solenoid, and it started right up. So much better if it's something simple, even it was still a pain.
Jun 11, 2013 | Husqvarna Garden
To replace transmission control solenoid on my dodge caravan 2000
It is inside the Transmission Pan.. Depending on which Solenoid you need to change
Apr 13, 2013 | Ariens Lawn Mower Universal Solenoid...
BATTERY HAS FULL CHARGE WHEN I TRY TO START IT IT DOES NOT TURN OVER NO CLICKING NOTHING CAN SOMEONE HELP ME. ARIENS 1740
Check to see if the solenoid is getting power. On the solenoid there are 3 wires. Two big, one from the battery, the other going to the starter. The 3rd wire is what activates the solenoid. Using a test light or volt meter. See if its getting power on the small wire when you turn the key. If no power, ignition switch, safety switches or fuses. If you are getting power replace the solenoid. If you have 4 wires. Test the two smaller ones.
Oct 17, 2012 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Ariens Sierra 1440H Lawn Mower
the solenoid is sticking inside the housing
Apr 30, 2010 | Ariens Lawn Mower Universal Solenoid...
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Ariens Zeroturn 2660 Hd 60" Riding Mower Logo
345 people viewed this question
Top Ariens Garden Experts
enb54
Level 1 Expert
Mike
Superior Maintenance
Are you an Ariens Garden Expert? Answer questions, earn points and help others
