Question about Sony FD Trinitron WEGA KV-20FV300 20" TV
TV automatically switches to channel 666.
All of the sudden, telivision starting changing channels on its own. it would go to 6 then 66 and display turned to 666. Thought it was a remote control problem so took the batteries out of it and same problem occured. Tried covering remote control receptor with finger and that only delayed the switching. this morning, I was able to get it to stay on one channel but the display went back to 666.
  • tunnelspc Apr 20, 2008
    Thanks for the response. Not only did I take the batteries out, I put the remote in a different room. No difference. Also there is nothing new that was brought into room. So if it is a software problem, is that something that can be fixed by local repair shop or will the repair bill be more than the value of the TV?
  • 36 Answers
Sounds like a bit of a devil(lol),could be interferance from a device causing this problem,have you got a flourecent light in the room,this is known to interfere with the tv's remote sensor,also try taking the batteries out of the remote???
Failing this it could be a fault in the tv,an i.c. has become corrupted and will need software to be re-installed but this is the worst case scinario.
Posted on Apr 20, 2008
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Channell lock
i find out that some channel are locked on my telivision with a padlock sign. How can i unlock this channels
Aug 24, 2008 | Curtis CM25101S 25" TV
Suddenly the Tuner mode reports "No Signal"
Just a solution.
I attached a video recorder., and selected the video channel.
I was able then to see the channels through another AV slot extension.
Then I reset the TV to factory settings.
Samsung full HD reset code is 0000.
I used the original remote control.
I pressed the button TV/DTV to switch between mode., and from the menu I started
the option to scan the channels automatically.
Because the VCR was still connected it looks like it was forced to admit the channels.
I turned off the VCR and click on the TV the remote control for a known channel ( alternative control used) and surprise ... The TV started to react according to expected.
I disconnected then physically the cabling from the VCR and plugged in directly on back on the
wall connector. All is ok.
What was the reason ?
My wife dropped the alternative remote control ( not the original one) on the floor, and apparently an strange code was sent to the TV., which suddenly displayed " No signal".
I hope this can work for you.
Kind regards
Sanchez
Aug 21, 2008 | Televison & Video
Tuner doesn't work
I think this may be more of a fault with the uPC area on the main board than a tuner failure. It is possible to have both at fault, but this would be rare.
The numbers you see on the screen is from a pre-scaler circuit that drives a font generator in one of the IC's near to the uPC area. If you see the numbers changing this more from the uPC than from the tuner iteslf.
Jerry G.
Apr 09, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-20FV300 20" TV Logo
198 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
