Question about Dell Studio 1535 Notebook
Battery not charging? Help please. - Dell Studio 1535 Notebook
    Scholar:
  • 96 Answers
How old is the battery? Usually, batteries only have 1 yr of life. It will start degrading when it is near its 1st year. You should consider that as well. You can try to take the battery out of the laptop and drain its power. Meaning, you would have to leave the computer without the battery and the ac adapter for at least 2 minutes. You can also press the power button while doing so to ensure its completely out of power. Next, plug in the AC adapter and turn your computer on without the battery (yes without the battery. This would check if your AC adapter is doing fine as well. If it does not turn on, you are having troubles with the AC adapter as well). After turning it on, allow windows to load and have the computer detect that it doesnt have a battery. You would see the icon that the battery is not connected. Next, turn your computer off and connect the battery. Unplug the AC adapter and turn the computer on. Wait until windows loads and then connect the AC adapter and see if you will still get the same message. If you would still be prompted that the battery is not charging, the last option before getting a new battery is to reinstall the Operating system. Sometimes, the problem that you are having is also a result of a failing power driver in the Operating system.
The easiest way to check is to put a known good working battery of the same model into your computer to check if its really the battery that you are having problems. If other batteries work, you should replace the battery that you have immediately. If it doesnt, its the laptops charging port that is having problems. If the laptop is still under warranty, you can have it brought to the service depot for repairs by calling DELL. but try doing the solutions that I have mentioned before doing so.
Hope this helps.
Posted on Jul 14, 2010
Chevy van g20 year 1994 the battery dies has new battery and new alternator but each mornin its dead need to charge the battery need help have any ideas and please talk problem please
you are going to have to check for a draw on the system and find what circuit the draw is on then check out that circuit and repair.
Aug 20, 2015 | Cars & Trucks
Hi. Sorry. My phone is i9300 when connected charger error is stopped charging battery temperature too high. Please help me. Tanks
check the battery composition you are trying to charge
some chargers will only charge lithium batteries and not charge nl.mh batteries as they charge too fast and over heat the battery
check the voltage of the charger as it may be incorrect for the battery
Jun 23, 2015 | Cell Phones
How do i charge the battery on a 1992 honda shadow vlx 600c
First check the battery voltage using a multi-meter set to DC and volt range if reading is below 12V battery has probably one dead cell get a new one, if between 12v and 13V battery should be OK to charge. Remove battery undo negative lead first then positive. Please do not use a car charger or any other charging device that has an output greater that 1 Amp you will fry the battery. Charge the battery for as long as possible. Recheck volts across the battery if above 13V refit battery connect positive lead first then negative.
Start your engine, when warmed up check the voltage across the battery terminals it should be well above 13 volts. Increase the revs and watch the meter the voltage should increase to about 14.5 volts. This shows the battery is being charged. Please remember batteries on bikes only last a few years and short rides do not put enough charge in your battery. Buying and using a motorcycle Smart charger does help. I use a CTEK XS 0.8 12V Motorbike Battery Smart Charger & Conditioner. You get a small wiring harness that fits to the battery with a rubber connector that connects to the chargers plug. This unit will help to keep the charge in the battery topped up.
Jan 10, 2015 | Honda Motorcycles
I have toshiba tecra a9 leptop it takes long time to charge minimum 3 hour what is the error please help me
How old is the battery? Do you use on battery alot? The battery will charge until it is full, times will differ? If you use on AC most of the time remove the battery.
Dec 30, 2012 | Computers & Internet
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
I am unable to charge my laptop.please help me out
Hey,
I am faing the same issue with my laptop which is an HP. The service tech says that the battery has gone bad and needs replacement.
Please visit the nearest service station and get the unit checked.
Jul 10, 2010 | Lenovo 3000 Y410 Laptop
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Dell Studio 1535 Notebook Logo
108 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
