Question about HP C4680 All-In-One Inkjet Printer
C4680 keeps jamming when I print on photo paper
My HP C4680 keeps jamming when I print photos onto photo paper. It's not cheap paper. Is it a fault with my machine?
  • 524 Answers
Hi...
please check weather the paper you inserted are with in this range
A4, legal, envelopes: 75 to 90 g/m²; cards: up to 200 g/m²; 10 x 15 cm photo: up to 280 g/m²
if the paper you inserted exceeds this weight the problem may occur
please vote me if my answer was usefull to you
Posted on Jul 14, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
How do i print on photo supreme paper?
Not all printers can print on all photo paper stock. Check with HP and see if your printer can usethat paper. Sounds like it is too heavy/thick.
Feb 28, 2015 | HP LaserJet Office Equipment & Supplies
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have trouble printing photos on photo paper. I
Hello there you can gaveit a go.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2010 | HP Photosmart C3150 Printer
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
HP 1510 - Photo Paper Jams
Hi, try using HP brand photo paper, HP makes their special photo printers and special photo paper for them.
The surface of the back of the HP's paper is rough, like sandpaper to avoid the paper being jammed in the cheap loading mechanism of their actual printers.
Oct 11, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP C4680 All-In-One Inkjet Printer Logo
249 people viewed this question
Seeker5211
Seeker5211
