Question about IBM Lenovo ThinkCentre M55e PC Desktop
Sound card doesn't work - IBM Lenovo ThinkCentre M55e PC Desktop
  • 487 Answers
Hi, Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to start button, control panel, system, hardware and select device manager. Click the + for your sound device and see if there are any problems, if so it will be highlighted with a yellow? right click your audio and update your driver. Or go to Google and search for the latest driver to download.
Hope this helps
Posted on Jul 14, 2010
No sound
on board audio... remove all traces of software (uninstall sound card software) remove device (uninstall sound device in device manager)
restart computer, if it finds sound device, install software.... if it doesn't, turn off sound card in CMOS and install daugter card sound board dependant on available expansion slots
Apr 16, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Sir my audio player not working
Try the following:
Restart the computer
Check the volume settings on your computer and speakers
Uninstall the sound card driver and restart the computer
Download and install an updated sound card driver from the manufacturer
If that doesn't work pleae post back what operating system you are running
Sep 07, 2011 | Computers & Internet
Cant get sound
This can often be as simple as the speakers being unplugged, plugged into the wrong jacks, or powered off, so don't overlook the obvious and check to be sure. Also check the volume controls in Windows or your application to see that they are turned up and not muted. When you are sure the volume is turned up, the speakers have power and are plugged in, and the speaker configuration is correctly identified in Windows (some audio hardware uses a proprietary mixer control for this job), you need to verify whether the problem is with the speakers or the sound card. Connect different known-good speakers and see whether they work. If they don't, the issue is in the sound card-possibly the configuration of the card is incorrect or the card itself is defective. The first thing to try is clearing the ESCD in the BIOS Setup. This essentially forces the plug-and-play routines to reconfigure the system, which can resolve any conflicts. If this doesn't help, try removing and reinstalling the sound card drivers. Finally, if that doesn't help, physically remove and replace the card from the system. You might try replacing it first in the same slot and then in a different slot because timing issues can sometimes exist from one slot to the next. If that doesn't work, you must try replacing the card. If the sound "card" really isn't a card but is integrated into the motherboard, first try the ESCD reset and driver re installation. Then, if that doesn't work, you have to try disabling the integrated sound and perhaps installing a replacement card.
I hope one of these solutions help.
Sep 05, 2011 | Systemax AOL Optimized PC (100607) PC...
My sound isent working on reason 3
I can't remember if reason 3 settings are setup like version 4 and 5, but you should find the audio settings under the edit / Preferences menu. In the page drop down box press Audio. Now in the Audio Card driver, select DX Primary Sound Driver. This will use the same driver that windows does. If you see one that says ASIO use that as it is lowest latency. If that doesn't work you may need a better sound card. Reason 3 does not support a lot of generic sound cards. You might also try downloading the latest driver for your sound card, I could help you locate a driver if you give me the model of your PC and / the model of your sound card.
Chris
Jul 01, 2011 | Propellerhead Reason 3.0 (991010004) for...
I have an ASUS M2N-MX SE Motherboard and I have a Creative Sound Blaster Live 5.1 digital internal sound card (SB0220) I wish to install in the PCI slot on the mainboard. Windows XP recognises the card and...
Try to reattach your sound card. It will solve the problem. If it doesn't work you can format your computer or clean the viruses on your computer. If problem still occurs change the sound card.
May 15, 2011 | Computers & Internet
DRIVERS SOUND
1) Try uninstalling the sound card in the device manager tab. Then reboot the computer and let windows install it again. And if that doesn't work go to step 2.
2) Go the sound card manufacture website and download the update driver for the card.
Apr 30, 2011 | Computers & Internet
Sound card Installer
please give details of your pc, i ill give the exact driver that suits your motherboard..
Thank you....
Jan 27, 2009 | Compaq Audio card Sound Card
Sound device not working
Windows XP
START - My Computer (RIGHT CLICK) - Properties - Hardware Tab - Device Manager button - click on the sound, video and game controllers - on the drop down menu you should see sound codec - either right click and UPDATE DRIVER - or delete sound codec’s and restart, XP will install suitable sound drivers.
If that doesn’t work then try installing sound drivers from the computer manufacturer.
If you have a big X on the sound codec or your third party drivers than it’s a hardware issue.
If replacing the drivers’ doesn’t work then it's a hardware issue. If you have onboard sound card then you will need to replace the mother board. I hope it's under warranty.
Jun 29, 2008 | Computers & Internet
Sound card problem
i have a sound card an i installed but driver s not installed ,an i need the right driver
Apr 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
IBM Lenovo ThinkCentre M55e  PC Desktop Logo
147 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
