Question about Braun 4775 Electric Shaver
Where do I find replacement batteries for my Braun 4775?
    New Friend:
>These units are not really made to be taken apart.
totally false. there are two plugs on the bottom that reveal two T8. loosen those and the shaver slides right open, there's even a video on youtube showing how easy it is to open. The seals are all rubber gaskets, there is no seal that gets "broken" by opening in this way. The batteries aren't even soldered down! pop them out and pop in replacements. easier to replace batteries in this model than most others due to no soldering required. I'm having a little difficulty finding the AA size batteries with the pin ends though, there's someone on ebay right now selling the AAA size with pins, I'm contacting them now to see if they can get the AA that the 4775 uses.
Posted on Dec 16, 2012
  • Braun Master
  • 1,625 Answers
You will find compatible batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Jul 15, 2010
    New Friend:
As posted above, shaver is easy to open.
I used 2 garden variety Eveready 2450 mAh NiMH rechargeables (no pins, no problem) from Super Store...NiMH because I had them on hand.
They're a tad short, so I inserted some folded aluminum paper on the Negative ends to take up the slack...done.
The batteries are solidly in place.
Shaver worked immediately, and is behaving normally while plugged in to recharge (green LED steadily lit as it should be).
We'll see how the NiMH batteries do in the NiCad charger. I can always replace these batteries with NiCad's.
Posted on Dec 02, 2013
5 Suggested Answers
brector3
  • 1625 Answers
SOURCE: how much is the cost
You will find original Braun replacement batteries for model 4775 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nicd-2-batteries-p-454.html
Posted on Aug 29, 2011
micromatikal
  • 2777 Answers
SOURCE: Got the plugs and two
These units are not really made to be taken apart. They are sealed internally... when you send them back to the factory they actually crack them open to repair them, then replace the case. You may want to contact Braun for the repair, I know they have a very good warranty on them, and it may be free. You may have already checked, but never hurts to check again and see if you get a friendlier support person :)
Their number is:
1-800-272-8611
Posted on Sep 11, 2010
  • 79 Answers
SOURCE: Braun 4775 Electric Shaver Power cord
I would visit this website: http://www.braun.com/na.html
They have a link for replacement parts and a Contact Us link. By contacting Braun, you may get the name/address of the nearest parts dealer. I would think Los Angeles has a bunch
of repair shops and parts dealers.
Posted on Mar 23, 2008
  • 2926 Answers
SOURCE: braun smart control 3 4775
Are you referring to the small blade for the mustache trimmer or the small blades for the shaver.
Posted on Jan 11, 2011
How to disassemble a Braun 5742 electric Shaver?
shaveroutlet.com has a video for this. See link below
http://www.youtube.com/watch?v=v_XsmqA_YTk
Feb 05, 2014 | Braun 4775 Electric Shaver
Broken trimmer
I You Have Not Already Done So, Contact Braun. Most Shavers Do Not Offer Repair Service Or Parts.
Oct 06, 2013 | Braun 4775 Electric Shaver
The 4775 unit seems to take a charge but it does not run? It's making a light buzzing sound? I've opened the unit, checked the batteries and they seem fine?
If the unit is more than a year old, the batteries may well be dead...you would need a tester to measure the charge in the batteries. It's cheap to change them.
The shaver is easy to open:
http://johnfixesstuff.blogspot.ca/2013/02/how-to-replace-batteries-in-braun-4775.html
I used 2 garden variety Eveready 2450 mAh NiMH rechargeables from Super Store...NiMH because I had them on hand.
The batteries fit solidly in place.
Feb 03, 2013 | Braun 4775 Electric Shaver
The battery is not charging al the way to a full charge
hello lonnie. take the shaver and the battery and the charger and cord to any radio shack and they will test it to determine which component needs to be replaced. Joe
Jun 13, 2011 | Braun 4775 Electric Shaver
When I charge my Braun it does not charge.But sometimes it charge. I do not know what to do
i have series 3 wet and dry braun shaver when it ison charge it only sends ared light to show on grip never it blue charge what is possibly wrong
Feb 23, 2011 | Braun 4775 Smart Control3 Razor Series 3...
Charging does not work and is immediately empty
I believe that you are stating that your model 4775 Braun shaver no longer holds a charge. To repair this you will need to replace the batteries. To replace the batteries, you will need to open the shaver up. First, remove the two round plastic screw covers on the bottom of the shaver then remove the screws that are underneath. The outer casing will then slide off the bottom of the shaver. You will then be able to access the batteries.
You will find batteries for model 4775 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nicd-2-batteries-p-454.html
Mar 01, 2010 | Braun 4775 Electric Shaver
Can i get replasment foil and head
braun series 3 combi 30B screen foil and cutter block for braun 4775 blades replacement parts.
Jan 21, 2010 | Braun 4775 Electric Shaver
Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN  SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
Mar 26, 2009 | Braun 4775 Electric Shaver
Mar 22, 2008 | Braun 4775 Electric Shaver
Braun 4775 Electric Shaver Logo
2,498 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
