Question about Swann Communications SW242-SR4 Video Recorder
I'm looking for the software SW242-SR4 - Swann Communications SW242-SR4 Video Recorder
Unique On and Off IR codes
ahhh.ok..what is the model number of the PRONTO, please?
May 31, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Tip
GSM alarm system with RFID & APP control and Touch keypad
Name:GSM alarm system with RFID & APP control and Touch keypad
Memo:
products introduction
??Features:
??Multi-languages voice; system volume is adjustable (low, medium and high);
??99 RFID cards to arm, disarm, and control the relay;
??SMS notification for disarm by RFID card; SMS content (of the first 10 cards) is editable;
??12-second voice message: by control panel or remotely;
??Broadcast system time and play voice message;
??Use panel as a telephone to make calls;
??Set the by control panel, SMS or remote calls;
??10 remote controls, 99 wireless and 2 wired defense zones;
??Sensor low power alert and tamper alert;
??Some of SMS alarm contents are editable;
??SMS alert for control panel tamper, low power, power failure/ recovery;
??Remotely control the relay.
REV M White SUNRAY 800 HD SE SIM 2.10 Card SUNRAY DM800 HD SE A8P ALPS M Tuner SUNRAY DM800 HD PVR SIM210 with Wifi HDMI SIM 2.1 Cable receiver.SUNRAY DM800 HD SE A8P card SUNRAY DM800 HD SE A8P card ALPS M Twin Tuner SUNRAY DM800 hd Pro Alps Tuner REV M SUNRAY DM500 hd Pro satellite Receiver ,wholesale cheap discount price.alarm security systemVU SOLO 2 SE Twin tuner SOLO MINI 3LED DisplayLED signLED Display ScreenOUTDOOR LED sign large LED DisplayOUTDOORLED SIGN BOARLED DisplayFlexible CurtainLED Dance Floor Display FullCOLOR OUTDOOR Led Sign led screenoutdoor led displayled displayindoor led displaytransparent led displayled display lightingled video wallchina led displayfull color led displayled screensflexible led screenrgb led displaylarge led displayled curtainled dance floorfull color led displayout door led displayled display manufacturerssmd led displayled dance floor for saleled display, led curtain, led mesh for stageoutdoor led screenadvertising led displayindoor led displaystransparent led screenled meshled displayled screenA8p card SUNRAY SR4 V2 Rev.E jynxbox store
dreambox dm800 hd se v2alarm security systemdreambox dm7080dreambox dm7080dreambox dm820dreambox dm7020 hd v2cheap wholesale dreambox dm800 hd v2Sunray SR4 V2 Sunray SR4 800 se Sunray SR4 hd se JynxBox Ultra HD V14JynxBox Ultra HD V16JynxBox Ultra HD V15Dreambox DM7080 HD PVRDreambox DM820 HD PVRDreambox DM8000 HD PVRDreambox DM7020
on Mar 29, 2016 | NU -set Gsm Padlock Alarm System -...
Honda ballade 1.8i sr4 timing digram
I think this video is the same procedure.
Sep 13, 2012 | Cars & Trucks
Jandy aqualink sr4 no light no response
make sure 4 pin plug is plugged into board and controller
Jul 28, 2012 | Jandy Aqualink Rs4 One Touch Control...
Need to know where to look on my mower to find out what info I need to find a new belt for my Toro SR4 Super Recycler.
I believe you will need belt Toro part # 91-2258 Try Partstree.com or call 1-877-798-7278 they are great to work with and can guide you to id your mower and get you the right part.
Jul 05, 2012 | Toro Power Lawn Mower
No manual need advice on attachments
These are lenses of varying power, or magnification. The SR4 is a 4mm Ramsden, which theoretically will give high magnification. The H20 is a 20mm Huygens, less magnification but much more useful.
As magnification is increased, the image gets more blurred, and the object (like a star) becomes very very difficult to find and keep in view. I would throw the SR4 away.
the 1.5x erecting eyepiece is a terrestrial viewing eyepiece of x1.5 magnification, which shows an image right way up, and 50% closer.
The 2x Barlow is a tele-extender which halves the focal length of an eyepiece and doubles its magnification. It is mounted between the eyepiece and the scope. A 15mm eyepiece becomes a 7.5mm when used with the Barlow.
You will probably use the 20mm and 15mm mostly by themselves though.
Here is further reading
http://www.rocketroberts.com/astro/first.htm
Mar 29, 2012 | Optics
How do I remove the blade of my SR4
This is from the Toro owners manual for SR4 euper recycler model 20058 serial number 250003464
The steps and picture are on page 18 of the manual 3352-864[1].pdf
You can enter those numbers on this page for a manual:
https://lookup3.toro.com/request/request.cfm
1. Disconnect the spark plug wire from the spark
plug. Refer to Preparing for Maintenance
2. Tip the mower onto its side with the air filter up.
3. Remove the
2 blade nuts (A)
and the
stiffener (B).
4. Remove the
blade (C).
5. Install the blade and the stiffener that you
removed in steps 3 and 4.
6. Install the blade bolts and torque them to 15 to
27 ft-lb (20 to 37 N?m).
The replacement blade part number is:
108-3762-03 (google / net search)
Thanks for choosing FixYa,
Kelly
May 20, 2011 | Toro Power Lawn Mower
Need software for Swann DVR4-1100 to work with Windows XP
Please visit the below website, ad then select the model number and the product to download the driver(software) of your DVR. The product should be on the box or on the original invoice of the DVR.
You can download the product code SW244-DUM or SW242-DU2.
Please check on the invoice so download the right one, or else can try both of these one by one.anand_sachan_0.jpg
http://www.swann.com.au/s/techcenter/download
Regards
Anand Sachan
Nov 05, 2010 | Swann Communications PC-DVR-4 NET...
Swann Communications SW242-SR4  Video Recorder Logo
138 people viewed this question
Top Swann Communications Televison & Video Experts
Lawrence Oravetz
Jack Frost
Jonathan Ashkenaze
Jonathan Ashkenaze
Are you a Swann Communications Televison and Video Expert? Answer questions, earn points and help others
