Question about Jet JWS - 22CS / 708320 1 - 1/2 HP Woodworking Shaper
Are the jet 22 shaper parts interchangeable with the reliant shaper DD34
2 Suggested Answers
  • 10865 Answers
SOURCE: HI, I have a reliant
hello jjpm..... I have had success with these parts at:
Eric Fairfield, Parts Manager
ericparts@woodworker.com
800-545-9663
Joe
Thanks for choosing Fixya!
Posted on Mar 19, 2011
I have a 14 year old Aker whirlpool tub. During bathroom remodeling, I found a leak where the pipe comes out of the jet. I could not repair it. Are the jets available yet? I found two numbers on the...
Jet bodies match only the jet trim that goes with them. These are a set and are not interchangeable with other models or brands of jet. Each Bath Part in unique in subtle ways only.
In order to find the correct jet body you need to match up the face of the jet trim to what is shown online. Once you know that brand of jet trim we can find you the correct jet body.
I would invite you to search our site at US Parts Center and see if you can find the jet face that you have.
Once you do we will be able to match up the correct jet body for you.
Rod
US Parts Center
888-521-6183
Jan 15, 2013 | Whirlpool Royal A-909 Bathtub
How do you lock the spindle on a JET JWS-18HO in order to change the bit?
Screw a starting pin ( see manual) into the base plate then cut a small block of wood that engages the face of the cutter and the starting pin. This locks the spindle and stops it moving. Use the supplied spanner and tap with a mallet. Tap the cutter to loosen it. Dave and Graham.
Jun 18, 2011 | Jet 708319/JWS - 18HO 1HP Shaper 1Ph 115...
Is a thermostat housing and a water outlet the same part? Every time I search for a thermostat housing all I find are water outlets.
Yes and no, at most auto parts stores they usually use the term "water outlet" to refer to the upper portion, the lid if you will, of the thermostat housing. This is the part that the upper radiator hose connects to. It looks like this:
Most times shops and parts stores use these terms interchangeably though. The thermostat in your car sits in whats called a water box, which the coolant temperature sensor connects into and is capped in by the housing/water outlet. I would just ask, if you are being told by a shop, if you just need the piece that connects to the radiator hose and bolts over the thermostat or if you need the the outlet and the water box.
Nov 10, 2010 | 1988 Plymouth Reliant
Looking for 22" blade for a Poulan - PO550N22SH - PN 961120080 - where can I buy a lawnmower blade? Can find the number on the internet, but can't find a dealer that sells this product.
Your Poulan Pro mower is made by American Yard Products and the parts will interchange directly with Craftsman 22" mowers. You should be able to find a replacement at your local Sears store. All of these part #s are also 22" AYP blades:
AYP #'s
406713
192682
157101
335256
114886
141114
Rotary #15-6236
Oregon #
95-043
95-042
95-055
95-023
95-021
95-602
The different #'s should all fit. Some of them are bagging style blades (high lift) while others are designed to mulch.
Online sources will include www.searspartsdirect.com and www.amazon.com
Good Luck!
Aug 25, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Need to find replacement capacitor for jet jws 18ho shaper
Get the micro farad number and the voltage rating and order it from...
www.grainger.com
Jul 02, 2009 | Jet 708319/JWS - 18HO 1HP Shaper 1Ph 115...
Brake light stays on
code 22 is a problem at coolant temp.sensor voltage too high or too low,the brake warning light could mean that fluid is low and u have a lost of pressure,brake line leak,leaking rear brake cylinder,worned out brakes,defective master cylinder or a defective handbrake and the switch stays on.youll have to check brake system!
May 27, 2009 | 1987 Plymouth Reliant
MANUAL
As you probably know, Reliant was the brand name of tools made for Trend-Lines, Inc. that became Woodworkers Warehouse who went out of business in 2003. Woodworkers Supply took over the Woodworkers Warehouse internet domain, http://www.woodworkerswarehouse.com/ , but did not take over the Reliant or Trend-Lines tools. Woodworkers Supply states that they will try to provide assistance with questions about Reliant tools so you may want to contact Eric Fairfield, Parts Manager, ericparts@woodworker.com, 800-545-9663
Oct 04, 2008 | Masonry Tools
Jet JWS - 22CS / 708320 1 - 1/2 HP Woodworking Shaper Logo
476 people viewed this question
Top Jet Tools & Hardware - Others Experts
Tom Chichester
Rick Ursell
Rick Ursell
Level 1 Expert
Are you a Jet Tool and Hardware - Other Expert? Answer questions, earn points and help others
