Question about Canon PowerShot G7 Digital Camera
The camera is off, but the lens are out, like if it is on and i can't switch it on! What shall i do?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 14, 2010
Your camera probably got a short as it's common on these. You'd need to get it serviced by a technician for it to turn on again.
Posted on Sep 26, 2010
I just rented a 2.8 70-200 L series and my camera will not auto focus so it won't take a picture
You haven't stated which exact Canon body you have. Not all of them can operate the AF motor built into that lens. I shall assume that you haven't left the focus switch set to manual.
Given the lack of detail I can therefore only suggest that you make sure that the electrical contacts on both the camera and body are clean and intact and then to either use the lens in manual focus mode or to return it to the rental company for a replacement.
Feb 22, 2011 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
My canon power shot sd630 fell down and the lens does not function.it says lens error, restart camera.where shall I take it for repair and how much it costs to repair
You could try you local electrical or photo retailer but I'd get a quote first. I don't intend to be rude but its likely the repair could cost more than the camera is worth.
Mar 14, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I am a beginner and cannot seem to get my lense of the camera, it feels like it is locked on. what shall i try do
Press and hold the release button (located on the camera body, next to the lens mount). Turn the lens counter-clockwise (approx. a quarter-turn, slightly less) and take it off.
If this doesn't work, please describe what exactly goes wrong (can't depress button, can't turn lens, etc.)
Mar 11, 2010 | Canon EOS 40D Digital Camera
I have canon cameral model sd 700 whose lens will not close.  i get the message to restart but repeated on and off will not restart; what shall I do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 22, 2009 | Cameras
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
Zoom lens/flashlight don't retract.
replace zoom lens strip and please do let me know where it is available I too have the same problem
Jan 12, 2008 | Kyocera Finecam S5 Digital Camera
Lens front cover
visit camera store bring your camera lense show what cover , for temporary cover a soft cloth keep .put absorbent shashy.
Dec 24, 2007 | Minolta 35-80mm f/4-5.6 II Lens
Automatic lens cover is stuck
The lens mechanism is damaged.The only known solution is to get a replacement lens unit and replace it
Aug 08, 2007 | Vivitar Vivicam 5388 Digital Camera
Canon PowerShot G7 Digital Camera Logo
237 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
